Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 9:30am and include delivery.
Kef Reference 104/2 Bi-Amp question pete the bus Hi Fi Systems and Separates 3 10-01-2008 10:55 PM
Questions about Atacama Europa Ref 8 treefrog AV Stands, Cabinets, Seating and Furniture 1 30-05-2007 2:08 PM
Atacama Europa stands treefrog Flat Screen TV Brackets and Mounts 1 12-05-2007 7:44 PM
Reference Level Question mooky AV Amplifiers and Receivers 10 16-12-2003 12:49 PM
Old 06-04-2008, 8:48 PM   #1 (permalink)
homerpovey's Avatar
Thanks: Gave 573, Got 129
Atacama Europa Reference 6.5/8 question
Hi, would love a bit of advice on the above racks. (6.5 & 8)
I've got a Sagem Axium HD-D45 and need a stand to place it on. Due to the restictions of the space and the need to house my KEF iQ5's either side I need a reasonably narrow stand. I'm planning to house the rest of my equipment on a shelf near the tv so a 4 tier Atacama Europa seems about right. The 80cm Atacama Europa Reference 8 may be a tight squeeze and the 65cm Atacama Europa Reference 6.5 may be borderline for the TV. That's the history of my situation done now for the Q's.
1) The base of my Sagem is 65cm wide the same as the Atacama Europa Reference 6.5. I know it's a Hi-Fi rack but would this be safe as it's the closest TV stand I can find near to 70cm width I'd like.
2) The stand states each shelf can take a maximum load of 25kg but my TV is 30kg according to the specs. Do you reckon this will be ok
3) Are there any other stands out there that look nice around 70cm wide, 40-45cm deep and 65cm or above high. I've looked around the usual places but I'm struggling.
I may have to have a custom made one done if there's nothing out there but any help would be gratefully received
Why doesn't someone just pull out a 45 and bang, settle it? ...Want some tea?
My Region B/Free Blu-Ray sales/trades | My Region A/Free Blu-ray sales/trades
homerpovey is offline   Reply With Quote
Old 07-04-2008, 10:18 PM   #2 (permalink)
homerpovey's Avatar
Re: Atacama Europa Reference 6.5/8 question
I guess it is a long winded question
Old 11-04-2008, 11:01 AM   #3 (permalink)
homerpovey's Avatar
I guess that means 'go custom' then
atacama, europa, question, reference
