Help finding an av unit around 2.5 metres wide
Old 05-04-2008, 10:10 PM   #1
6,093, Level: 18
Points: 6,093, Level: 18 Points: 6,093, Level: 18 Points: 6,093, Level: 18
Thanks: Gave 4, Got 29
I'm tryign to find an av unit approx 2.5 metres wide. Anyone know of any that don't cost the earth...?
Old 06-04-2008, 1:35 AM   #2
4,482, Level: 15
Points: 4,482, Level: 15 Points: 4,482, Level: 15 Points: 4,482, Level: 15
Thanks: Gave 25, Got 6
Re: Help finding an av unit around 2.5 metres wide
Hi I have an Alphason AV Cabinet that is finished beautifully in black. I did consider buying two as side by side they look like one, but could not get WIFE planning permission!
http://www.alphasondesigns.com/produ...ID=90&CatID=33
Good luck.
Old 06-04-2008, 7:21 AM   #3
6,093, Level: 18
any piccys?
Old 13-04-2008, 6:08 AM   #4
3,186, Level: 13
Points: 3,186, Level: 13 Points: 3,186, Level: 13 Points: 3,186, Level: 13
Thanks: Gave 8, Got 5
This thread has some pics of two alphasons
Opinion needed on Alphason ABR 1100-B please
Old 15-04-2008, 10:02 PM   #5
1,956, Level: 10
Points: 1,956, Level: 10 Points: 1,956, Level: 10 Points: 1,956, Level: 10
Thanks: Gave 6, Got 5
Cheap and cheerfull ....
2 of these @ £35 each ? You can buy doors raging from £6 upwards including clear / frosted glaxed doors @ £15 ish I think - they do have some nice dark finishes too.
Can be mounted on wall to give a floating shelf effect - albeit cabling may be difficult we are thinking of some getting some L shaped brackets made up to site unit on to give floating appearance with option to then to easily remove units for future cabling ...
http://www.ikea.com/gb/en/catalog/products/20102149
