Energy Take 5.2 Speaker Stands
Old 02-04-2008, 9:42 AM   #1
5,258, Level: 17
Points: 5,258, Level: 17 Points: 5,258, Level: 17 Points: 5,258, Level: 17
Thanks: Gave 51, Got 10
Hi all
I have an Energy Take 5.2 speaker system which I bought around 5 years ago. At the time I purchased 2 of the speaker stands that came with it. I am now in the position (new house) where I need a further 2 stands but as the system is now discontinued, I am finding it impossible to hunt down.
As far as I can remember, the stands were twinned with the system. This is where I will sound like a total novice, but the stands have a kind of pin/screw coming out the top of them where you stick the back end of the speaker, and then tighten the bolt on the screw to stabalize the speaker.
In all honesty, I am not after the same kind of stands - although would be if they still existed. What I am after is some form of speaker stand that has a similar kind of connection. I hope I have explained this ok above! If anyone can help me it would be MUCH appreciated!
