Advice please on centre positioning
Old 28-03-2008, 6:42 PM   #1
danmc_82's Avatar
8,051, Level: 21
Points: 8,051, Level: 21 Points: 8,051, Level: 21 Points: 8,051, Level: 21
Thanks: Gave 935, Got 373
Im currently doing up my lounge (thats why its a bit of a mess at the mo ) and im having trouble finding a place for my centre speaker. Im having a coal fire put into the fireplace and stone clading on the brickwork and on the lintle. Im obviously going to have to put a shelf above the lintle and below the tv to stop the heat from getting to my bravia.
The only other place I can think of is above the tv on a bracket of some sort. I dont want the tv to be any higher so I think having it below would look odd and cramped.
What do you guys think?
Old 28-03-2008, 6:50 PM   #2
Illustrious Member
Abbeygoo's Avatar
19,847, Level: 34
Points: 19,847, Level: 34 Points: 19,847, Level: 34 Points: 19,847, Level: 34
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 1,936, Got 2,083
Re: Advice please on centre positioning
Yeah I think it may well be cramped having it underneath the TV. I think you should give it a whirl above the TV ... can't imagine it would make a massive difference to the sound.
danmc_82 (28-03-2008)
Old 28-03-2008, 10:12 PM   #3
danmc_82's Avatar
8,051, Level: 21
Is there bracket you could advise me to get? Its for a MA LCR.
Old 30-03-2008, 10:41 PM   #4
danmc_82's Avatar
8,051, Level: 21
Anyone know of a good centre speaker wall bracket?
Old 03-05-2008, 10:44 AM   #5
danmc_82's Avatar
8,051, Level: 21
Old 08-06-2008, 11:16 PM   #6
danmc_82's Avatar
8,051, Level: 21
Anyone?
Old 09-06-2008, 12:09 AM   #7
5,708, Level: 17
Points: 5,708, Level: 17 Points: 5,708, Level: 17 Points: 5,708, Level: 17
Thanks: Gave 1, Got 6
Originally Posted by danmc_82 View Post
Anyone?
I'm after the same too. 2 x bumps reqd?
Old 09-06-2008, 3:31 PM   #8
danmc_82's Avatar
8,051, Level: 21
I have seen these on ebay http://cgi.ebay.co.uk/Centre-Speaker...QQcmdZViewItem
I might just make my own
Old 09-06-2008, 3:33 PM   #9
danmc_82's Avatar
8,051, Level: 21
Just thought scoo, what speaker you going to mount and where about? Mines going to be above the tv because I have the fireplace below
