wall corner mounts? do they exist
Old 20-03-2008, 8:57 PM   #1
3,804, Level: 14
Points: 3,804, Level: 14 Points: 3,804, Level: 14 Points: 3,804, Level: 14
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 59, Got 4
looking to wall mount a px80 panasonic but it needs to go into the corner, can someone recommend a suitable wallmount?? thanks
Old 21-03-2008, 7:40 AM   #2
3,620, Level: 14
Points: 3,620, Level: 14 Points: 3,620, Level: 14 Points: 3,620, Level: 14
Thanks: Gave 0, Got 22
Re: wall corner mounts? do they exist
Hi I would recommend our AVS-3005X1 I have my 42" Pioneer mounted in the corner on one and it works very well its a very strong bracket at a very good price at the moment. Alternativly if you want more flexabilty in the movement then look at the AVS-TV44.
talkinloud (21-03-2008)
Old 25-03-2008, 9:27 AM   #3
Member 263295
Posts: n/a
Hi talkinloud
If you are looking to mount your tv in the corner i would recommend the ChaseAV UNI57. This is on an articulated arm so can come away from the wall and sit nicely in the corner, it can also take up to 75kg and fits a variety of VESA mounting patterns up to 600 x 400mm.
Have a look around our site as I'm sure you'll find something to suit your needs.
Old 28-03-2008, 10:44 PM   #4
3,123, Level: 13
Points: 3,123, Level: 13 Points: 3,123, Level: 13 Points: 3,123, Level: 13
I got this for my 37" PX70
http://www.tlc-direct.co.uk/Products/SK129174.html
Old 30-03-2008, 12:45 PM   #5
3,654, Level: 14
Points: 3,654, Level: 14 Points: 3,654, Level: 14 Points: 3,654, Level: 14
Thanks: Gave 1, Got 1
try www.a2000systems.co.uk
