SVS-01 Speaker Bracket
Old 17-03-2008, 5:24 PM   #1
Pana440's Avatar
10,153, Level: 24
Points: 10,153, Level: 24 Points: 10,153, Level: 24 Points: 10,153, Level: 24
Thanks: Gave 476, Got 412
I currently have my rear speakers wall mounted using pretty much this but don't really like it as it feels too...cheap, if you know what I mean
Has anyone used these before as it looks a bit more sturdier. Or can anyone recommend any more?
Old 18-03-2008, 10:22 AM   #2
Pana440's Avatar
10,153, Level: 24
Re: SVS-01 Speaker Bracket
Old 18-03-2008, 8:13 PM   #3
1,719, Level: 9
Points: 1,719, Level: 9 Points: 1,719, Level: 9 Points: 1,719, Level: 9
Thanks: Gave 1, Got 8
I've not used the brackets you mention but have used Vogels kit before and would give it the thumbs up!
Pana440 (19-03-2008)
Old 19-03-2008, 9:55 AM   #4
Pana440's Avatar
10,153, Level: 24
Thanks, I guess the best bet is to just give them a go hey, they do look a lot sturdier though!
Old 19-03-2008, 10:11 AM   #5
Assured Advertiser
Kent Home Cinema's Avatar
14,413, Level: 28
Points: 14,413, Level: 28 Points: 14,413, Level: 28 Points: 14,413, Level: 28
Thanks: Gave 61, Got 423
Morning
Due to the weight of the speakers we have had problems sourcing wall mounts man enough to support the weight of the SVS speakers especially when they are tilted as a previous manufacturer stopped supplying mounts that fitted. We have now found a new mount and have stocks of these. The product will be added to our site later today and I will post a link on this thread.
Regards
Alastair
www.kenthomecinema.co.uk
Proud to be be supporting the AVForums as an Assured Advertiser
Home of the FrontRow Home Cinema Seating Visit our blog - here
Old 19-03-2008, 11:10 AM   #6
Pana440's Avatar
10,153, Level: 24
Originally Posted by Alastair Collie View Post
Morning
Regards
Alastair
Thanks Alastair, just what I am looking for too, look forward to the link
Old 19-03-2008, 11:53 AM   #7
Assured Advertiser
14,413, Level: 28
Hi again
Link to the wall mount for SVS speakers is
http://www.av-sales.co.uk/Speakers-a...B01-378-22.htm
Regards
Alastair
