Deep TV Stand
Old 16-03-2008, 9:05 PM   #1
2,765, Level: 12
Points: 2,765, Level: 12 Points: 2,765, Level: 12 Points: 2,765, Level: 12
Deep TV Stand
Anyone know if there are any fairly deep TV stands around, after looking at a couple websites I havent really seen anything amazing. The reason it needs to be deep is that it will house a pioneer VSX-LX60 which is 459mm deep, plus needs a bit of space for the cables to so imguessing 50cm really, and its 19cm in hight to, will also have a 50" pdp 508xd on the top, plus Xbox, DVD and Sky HD boxes. At the moment im thinking a corner stand as there will be some extra room at the back to push the units as it wont be touching the wall. This is the only one that has looks of any interest at the moment, just enough height in the shelf for the reciever, but could do with a little more depth, anyone got any other suggestions?
http://www.argos.co.uk/static/Produc...t>TV+STAND.htm
