Tall Tv stand for 42 inch LCD
Old 16-03-2008, 12:45 PM   #1
2,758, Level: 12
Points: 2,758, Level: 12 Points: 2,758, Level: 12 Points: 2,758, Level: 12
Hi all, As im renting and cant drill any holes in the walls im looking to get a TV stand for my equipment. I currently have the TV on a little table but want it to sit a bit higher so that the stand of the LCD (at the bottom of the screen) is around 60 70 or 80 cm's tall, if its higher I dont mind. I have a Onkyo 605 amp which needs some space to breath, PS3 which also pumps out some heat, KEF 2005.2 speakers so a center speaker to slap in the middle and a cable TV box that need a place to live so a minimum of 3 or 4 shelves.
Can someone reccomend something for me?
I guess my budget is up to £200
Thanks very much
Old 17-03-2008, 12:28 PM   #2
Member 263295
Posts: n/a
Re: Tall Tv stand for 42 inch LCD
Hi RaGzMaN
Have a look at the SupportsAV SD009-B, it has 3 shelves for all your equipment and measures 972mm from the floor to the top of the mounting bracket, if this is too expensive for you have a look around our website, I'm sure you'll find something that fulfills your requirements.
Old 18-03-2008, 8:24 PM   #3
1,719, Level: 9
Points: 1,719, Level: 9 Points: 1,719, Level: 9 Points: 1,719, Level: 9
Thanks: Gave 1, Got 8
Hi, maybe the Elmob range will have something for you. I am currently looking into getting myself one for my Sony Bravia.
Old 02-04-2009, 4:36 PM   #4
Member 363549's Avatar
1,937, Level: 10
Points: 1,937, Level: 10 Points: 1,937, Level: 10 Points: 1,937, Level: 10
Lightbulb Re: Tall Tv stand for 42 inch LCD
The Origin range of TV Stands might be suitable for what you are looking for. With one of these you don't have to drill into any walls.
Origin TV Stands
Regards
Chris
Old 03-04-2009, 6:56 AM   #5
Assured Advertiser
m-formonline's Avatar
5,121, Level: 16
Points: 5,121, Level: 16 Points: 5,121, Level: 16 Points: 5,121, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 20, Got 299
Sme nice alternatives here;
M-Form - TV Furniture
Some within your budget and some not. All high quality UK manufactured.
Regards
GRaham
www.m-formonline.co.uk UK Manufactured LCD and Plasma Wall Brackets.
info@m-formonline.co.uk see our blog or call 01159409169.
