Stand for 65" panasonic TH-65PX600
Old 15-03-2008, 9:35 PM   #1
2,813, Level: 12
Points: 2,813, Level: 12 Points: 2,813, Level: 12 Points: 2,813, Level: 12
Thanks: Gave 7, Got 3
After splashing out on a great panasonic TH-65PX600 TV, I can't find a stand I like for it that will also provide good cooling for my media center PC and (to be purchased) Yamaha RX-V1800.
Can anyone provide any recommendations? It will also need to provide a home for a V+ box and a SVS Centre speaker. I'm hoping that I'll be able to find something with a bit of style and wood/glass.
thanks in advance.
Old 16-03-2008, 12:27 AM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Stand for 65" panasonic TH-65PX600
http://www.homecinemauk.com/ look a spectral very good quality and well made this would be my choice http://www.homecinemauk.com/spectral...l1552/prod/77/
Features
Concealed castors for ease of placement
455mm height
12mm top shelf – 1505(w) x 525(d)mm
Choice of clear, frosted or black glass shelving
Toughened safety glass shelves
Supports a load of up to 100kg
Old 16-03-2008, 1:04 AM   #3
2,813, Level: 12
and all for only 1800 quid!!!!
Old 16-03-2008, 11:13 PM   #4
Assured Advertiser
63,997, Level: 61
well as you have a 65" plasma i assumed you had means and desired quality a couple of breeze blocks and a sturdy plank or 2 would work
