Glass Stand advice please
Old 16-01-2008, 3:10 PM   #1
Cloud Warrior's Avatar
2,675, Level: 12
Points: 2,675, Level: 12 Points: 2,675, Level: 12 Points: 2,675, Level: 12
Thanks: Gave 103, Got 73
Question Glass Stand advice please
after advice/opinion/links to a good priced glass 3 tier stand please.
due to the components that need to be on the stand it has to be around
1m + length. needs to hold 32 inch sammy on top.
next shelf will have ps3 and xbox 360
next shelf will have gamecube and soon to be amp.
due to trying to save for amp set up, budget is very tight atm. so not expecting the best bit of kit here, just something for now that will hold it all together looking semi good.
this is on offer atm at scan for just under £50
but again the cheaper the better . also would like clear glass as i intend to mess about trying to add some UV modding lights to give some nice effect eventually.
so if possible does anyone have any links to some bargains ?
