4/5 shelf AV stand with 25cm shelf height
Old 11-01-2008, 2:52 PM   #1
3,999, Level: 14
Points: 3,999, Level: 14 Points: 3,999, Level: 14 Points: 3,999, Level: 14
Thanks: Gave 23, Got 7
As per title, looking for an AV stand/rack with four or five shelves. Between each shelf needs to be a min of 25cm high clearance. Each shelf would need to support around 20kg. Would prefer in black or smoked glass.
All the stands I've seen have a high bottom shelf and the rest are quite short. Not looking to spend a fortune, around £100 - £150 max if possible.
Thanks.
