Optimum not up to scratch
Old 06-01-2008, 3:00 PM   #1
shep1968's Avatar
4,986, Level: 16
Points: 4,986, Level: 16 Points: 4,986, Level: 16 Points: 4,986, Level: 16
Thanks: Gave 4, Got 2
I have just had delivered a sparkly optimum rack in polished chrome. Started to put it together and noticed that every single rod had something wrong with it, from scratches to blemishes in the metal to poorly cut and rough ends on the plastics. Has this happened to anyone else or is it just my bad luck?
Old 08-01-2008, 7:06 PM   #2
5,421, Level: 17
Points: 5,421, Level: 17 Points: 5,421, Level: 17 Points: 5,421, Level: 17
Thanks: Gave 127, Got 25
Re: Optimum not up to scratch
Really interested to know how this turned out. I am about to purchase the AV300, which model did you get?
