Centre speaker stand
Old 05-01-2008, 8:07 PM   #1
8,104, Level: 21
Points: 8,104, Level: 21 Points: 8,104, Level: 21 Points: 8,104, Level: 21
Thanks: Gave 25, Got 91
Guys, trying to find a centre speaker stand but its not easy. Needs to be black and be about 12" tall. Something like this would be ideal:
That one is from somewhere in the US, so ideally need something in the UK.
Any suggestions on where I might find one? It could probably do with being rectangular instead of square as it is for a Mordaunt Short 903 which is quite long.
John
Old 05-01-2008, 8:52 PM   #2
BOOMERANGBUBB's Avatar
3,340, Level: 13
Points: 3,340, Level: 13 Points: 3,340, Level: 13 Points: 3,340, Level: 13
Thanks: Gave 119, Got 50
Re: Centre speaker stand
John
Hi John,
Have you seen these? This link will take you to the home page, If you look down the left handside in Speaker stands... S.STANDS-DUO. I know that they will take an order for just one if you ask them.
http://www.aivn.co.uk/
They are fantastic stands and look the the business!
Hope this helps
Keir
Clsmooth391 (13-01-2008)
Old 06-01-2008, 11:03 AM   #3
8,104, Level: 21
They look like they could well do the job! I like the taller ones aswell, so might get some of those for my fronts. Do you know how tall that centre one is? Thanks for the link
John
Old 06-01-2008, 6:02 PM   #4
3,340, Level: 13
Hi John,
Just give them a call! They are really friendly guys and are very willing to help.
Give em a call.
Glad I could help.
Keir
