Help me find a platform for my PS3 (pic inside)
Old 02-01-2008, 8:26 PM   #1
2,420, Level: 11
Points: 2,420, Level: 11 Points: 2,420, Level: 11 Points: 2,420, Level: 11
Thanks: Gave 30, Got 5
Evening all,
Im trying to find a platform to put my new PS3 on, I have absolutely no space at all with my current setup so at the moment the PS3 is going to have to sit on my Sky set top box covering its ventilation slits which obviously isnt an ideal position to be in.
I have no space for a proper AV stand so what im looking for is a kind of thin platform to sit over my set top box that the PS3 can sit on. Ive done a quick drawing in paint to try an illustrate what im looking for:
I know its an appaling attempt at a drawing but im sure you can see what im getting at! Ive looked in all the usual places and on eBay but I just cant find anything that ticks all the boxes.
I know I could easily make one myself but id thought id check out the professional options first.
Anyone know anything suitable? Thanks in advance.
Old 03-01-2008, 1:03 PM   #2
2,071, Level: 10
Points: 2,071, Level: 10 Points: 2,071, Level: 10 Points: 2,071, Level: 10
Thanks: Gave 14, Got 8
Re: Help me find a platform for my PS3 (pic inside)
Try looking at PC monitor stand that are used to lift PC monitors off your desk to the correct height.
Probably about the right size.
nichorob (03-01-2008)
Old 03-01-2008, 3:06 PM   #3
2,420, Level: 11
Thats a very good idea actually, never thought about that.
