Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 7:30am and include delivery.
Do i HAVE to use a DEDICATED CENTRE SPEAKER for my home cinema setup? or will any spe karl-ireland AV Amplifiers and Receivers 6 10-05-2007 8:35 AM
Using TV speaker as centre surround speaker (Sharp GAEe) woody67 LCD Televisions 0 04-04-2005 10:59 PM
Old 27-12-2007, 9:23 PM   #1 (permalink)
Thanks: Gave 8, Got 7
Centre speaker needs new home ....
Newsflash ...
a centre speaker that measures 460x172x192 (Length x Height x Depth in mm) and weights 7kg does not sit on top of a 42" LCD TV.
Does anyone here have a solution, there is no room under the TV, most new TV stands haven't enough shelves to hold .. DVD Recorder, VCR, DVD Player, Sky+, AV Amplifier, XBox. We got a really good wooden one from Ikea that works a treat and want to keep it.
So I need a stand that will hold the centre speaker that either goes under the TV or will hold the centre speaker over the top of it (a height of at least 720mm)
Ideas please ..... I am getting goofy eyeballs scouring the web ...
ScreechOwl is offline   Reply With Quote
Old 28-12-2007, 9:47 PM   #2 (permalink)
JimBobVFR400's Avatar
Thanks: Gave 22, Got 224
Re: Centre speaker needs new home ....
If it has a wall behind it then a shelf or speaker wallmount above the TV might work.
I have a similar issue. I ended up putting the PS3 vertically on the floor next to my stand because I can't findanywhere else to put my centre speaker. (my setup is in a bay window)
JimBobVFR400 is offline   Reply With Quote
Old 21-01-2008, 12:18 AM   #3 (permalink)
dieselpower's Avatar
Thanks: Gave 2, Got 1
I've now got the same problem. Amp, DVD, Sky+ and 3 games consoles are taking up too much room for my centre speaker to fit in the stand now.
Does anyone make a wall bracket for a centre speaker?
dieselpower is offline   Reply With Quote
Old 21-01-2008, 9:16 AM   #4 (permalink)
eviljohn2's Avatar
Thanks: Gave 76, Got 211
I made this DIY stand based on the TNT Flexy-rack.
Evil- Centre Speaker Stand
If I were to build another one I'd use a 3rd board in the middle to help stablilise everything.
eviljohn2 is offline   Reply With Quote
Old 21-01-2008, 9:17 AM   #5 (permalink)
Thanks: Gave 919, Got 472
Vogels are pretty good wall mounts.
Paulie-W is offline   Reply With Quote
centre, home, speaker
