Really low TV stand required??
Old 19-12-2007, 12:50 PM   #1
2,013, Level: 10
Points: 2,013, Level: 10 Points: 2,013, Level: 10 Points: 2,013, Level: 10
Thanks: Gave 6, Got 3
Hi everyone- i have a projector and use it as my main tv- the screen is 92", but i now want a normal TV (40"?) as i think that I'm getting too "used" to the huge projector screen
As the projector screen is fixed, is there any other low TV stand that will let me place the TV underneath the projector screen?
Thankyou!
Old 26-03-2009, 12:47 PM   #2
Member 363549's Avatar
1,937, Level: 10
Points: 1,937, Level: 10 Points: 1,937, Level: 10 Points: 1,937, Level: 10
Lightbulb Re: Really low TV stand required??
Hi There
This stand is suitable for your needs:
Ateca Monaco TV Stand
It is just over 40cm in height.
I hope this helps,
Kind Regards
Chris
Old 31-03-2009, 7:56 PM   #3
3,620, Level: 14
Points: 3,620, Level: 14 Points: 3,620, Level: 14 Points: 3,620, Level: 14
Thanks: Gave 0, Got 22
Firstly has the TV got a table stand (not all screens come with them as standard) if it has I would recommend the following.
Atacama Equinox AV (300mm high)
Stil stand Mellan Range (495mm high)
Alphason ambri range (330mm high)
