In Need Of A Glass Stand
Old 15-12-2007, 7:58 PM   #1
akane_1984's Avatar
12,879, Level: 27
Points: 12,879, Level: 27 Points: 12,879, Level: 27 Points: 12,879, Level: 27
Thanks: Gave 1,166, Got 146
Have seen this one at Amazon for £39.99 but don't know if its tempered glass or if the picture is showing cable tidy holes at back here if anyone could recommend me a stand I have a 32" LCD.
Old 16-12-2007, 11:58 AM   #2
akane_1984's Avatar
12,879, Level: 27
Re: In Need Of A Glass Stand
bump. .
Old 16-12-2007, 12:46 PM   #3
P-P-S-S's Avatar
7,274, Level: 20
Points: 7,274, Level: 20 Points: 7,274, Level: 20 Points: 7,274, Level: 20
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 246, Got 55
Those are cable tidy holes at the back and usually the glass is tempered. Best bet is to give Amazon a ring on 08002796620. hope that helps.
akane_1984 (16-12-2007)
Old 16-12-2007, 1:24 PM   #4
akane_1984's Avatar
12,879, Level: 27
didn't know you could call to check, thanks will give them a ring.
Old 16-12-2007, 4:01 PM   #5
Brutos's Avatar
3,776, Level: 14
Points: 3,776, Level: 14 Points: 3,776, Level: 14 Points: 3,776, Level: 14
Thanks: Gave 58, Got 71
I've got this stand in black, it does have holes in the back which you could use for a cable tidy, but i have no idea if the glass is tempered.
Either way a real bargain if you ask me.
Old 16-12-2007, 4:11 PM   #6
akane_1984's Avatar
12,879, Level: 27
well I found what seems to be the same stand here and it says that at least the top shelf is toughened glass.
