Wall Mount for Sony KDL32V2500
Old 12-12-2007, 9:21 PM   #1
liamwlk1971
Posts: n/a
I am looking for some advice on choosing the right wall mount for the above TV. I will be mounting on a partition wall, so may require a bracket with some lateral movement, so as to get TV in the right position.
I had thought about the Vogel's EFW6205 or EFW6305, but am not sure if they are compatible with this TV.
The screw holes at the back of the Sony measure 200mm horizontal by either 150 or 170mm vertical - is this VESA compatible?
Any advice on a good bracket choice appreciated.
Many thanks
Old 02-01-2008, 2:30 PM   #2
Rpm999
Posts: n/a
Re: Wall Mount for Sony KDL32V2500
I have a KDL32V2500, according to the Vogel's website, the EFW6245 and EFW6205 are compatible. For a complete list check out the flatscreenfitter section on www.vogels.com
Old 09-01-2008, 4:24 PM   #3
4,224, Level: 15
Points: 4,224, Level: 15 Points: 4,224, Level: 15 Points: 4,224, Level: 15
Try AV Rabbit (www.avrabbit.com). If you give them your TV details they will advise you on the best bracket. I have a Premier Mounts bracket for my 32" Tosh and have just gone for another Premier Mounts for my 42" Panny The AM3 bracket at £195). My bro has a Vogels - they look good, but the PM is more versatile. I would highly reccommend the PM - really solid mount
