Ateca stands
Old 02-12-2007, 5:25 PM   #1
5,007, Level: 16
Points: 5,007, Level: 16 Points: 5,007, Level: 16 Points: 5,007, Level: 16
Thanks: Gave 9, Got 3
Question Ateca stands
i'm after an Ateca Mon120 stand in red, or the soundstyle finewoods stand in oak.
does anyone have any pictures of these in their homes? ones off the net just dont give a proper impression.
Paul
Old 06-12-2007, 8:35 PM   #2
7,741, Level: 20
Points: 7,741, Level: 20 Points: 7,741, Level: 20 Points: 7,741, Level: 20
Re: Ateca stands
Hi Paul,
I can't provide you with a picture but having seen an Ateca Mon120 in red in a shop today I can tell you I'm going to buy it tomorrow. You're right though, the web pictures are terrile and I couldn't even find Ateca's website?
However, in the flesh the red was a brilliant high gloss red (not like the salmon pinks of the web pictures) and it looks a lot lower and longer in the flesh....less squat.
I hope that helps.....a little,
Greg
Old 30-12-2007, 2:32 PM   #3
ukdy's Avatar
5,094, Level: 16
Points: 5,094, Level: 16 Points: 5,094, Level: 16 Points: 5,094, Level: 16
Thanks: Gave 15, Got 35
Re: Ateca stands
i thought i'd give this a bump as i'm interested in it too...
Old 30-12-2007, 3:47 PM   #4
4,086, Level: 15
Points: 4,086, Level: 15 Points: 4,086, Level: 15 Points: 4,086, Level: 15
Re: Ateca stands
hifibitz have a good picture on their web pages
Old 31-12-2007, 9:46 AM   #5
porker's Avatar
4,360, Level: 15
Points: 4,360, Level: 15 Points: 4,360, Level: 15 Points: 4,360, Level: 15
Thanks: Gave 11, Got 3
Re: Ateca stands
Nice stand, I saw one the other day in House of Fraser.
I had to rule them out because of the shelf spacing, they are equally spaced so there is no way I could fit my amp in there.
Just make sure your gear isn't too high.
Old 01-01-2008, 9:11 AM   #6
tristan2's Avatar
7,735, Level: 20
Points: 7,735, Level: 20 Points: 7,735, Level: 20 Points: 7,735, Level: 20
Thanks: Gave 87, Got 47
Re: Ateca stands
im after the ateca cla100 stand ive found it for £150.00,but i cant find the details of the dimensions of the height of the shelves i cant find their website anywhere
Old 09-01-2008, 8:19 PM   #7
cjy cjy is offline
2,386, Level: 11
Points: 2,386, Level: 11 Points: 2,386, Level: 11 Points: 2,386, Level: 11
Re: Ateca stands
I too am interested in getting the Classique CLA100/BLK after getting some additronal dimension information from the distributor - http://www.bbg.eu.com/ateca_classique.html
Does anyone have any comments on experience with this stand?
P.S. the additional measurements are as follows:
- width between posts: front = 880mm, rear = 660mm
- gap between bottom & middle shelves = 240mm
- gap between middle & top shelves = 173mm
- depth from front of shelf to inside rear posts = 340mm
Old 10-01-2008, 11:31 AM   #8
cjy cjy is offline
2,386, Level: 11
Re: Ateca stands
For information, I found the CLA100 for £99.99 delivered at http://www.electeklimited.com/catego...&categoryID=11
Old 10-01-2008, 11:43 AM   #9
4,362, Level: 15
Points: 4,362, Level: 15 Points: 4,362, Level: 15 Points: 4,362, Level: 15
Thanks: Gave 1, Got 0
Re: Ateca stands
Greetings,
Ecran lounge sell the Mon 120 in red gloss for 269Euro, what's the
cheapest price in the uk?
www.ecranlounge.com
Product: AT141DP118
Actually 269E is for the Monaco/red 1000mm
Price for the Mon125 red so 1250mm is 359E
Old 24-01-2008, 4:20 PM   #10
3,171, Level: 13
Points: 3,171, Level: 13 Points: 3,171, Level: 13 Points: 3,171, Level: 13
Re: Ateca stands
Just got some dimensions for the Ateca Monaco from the importers which may be useful if you have large AV Kit like a receiver.
MON120 Lower shelf 14.0cm, Top shelf 13.0cm clear height
MON125 Lower shelf 17.0cm, Top shelf 16.5cm clear height.
My amp is 14.2cm, so its as well I checked!
Old 26-01-2008, 10:48 PM   #11
5,007, Level: 16
Re: Ateca stands
aaahhh, this old thread
good to see you got the dimensions, my amp is 15cm high so is too big for the MON120. Dont think i'm getting either of these stands now, funds wont allow it!
good luck to you guys though
Old 19-03-2008, 12:48 PM   #12
HUGA70
Posts: n/a
Re: Ateca stands
Pls somebody help me to find the name and the contact details of the exclusive seller/distributor of ATECA in US/Canada.
Tnx.
Old 06-06-2008, 11:42 AM   #13
2,496, Level: 11
Points: 2,496, Level: 11 Points: 2,496, Level: 11 Points: 2,496, Level: 11
Re: Ateca stands
Originally Posted by gpender View Post
Hi Paul,
Greg
I don't suppose you recall which store you saw the Ateca Monaco tv stand in? I've searched for it on the web but only found web retailers.
Phil
Old 16-07-2008, 9:48 PM   #14
2,352, Level: 11
Points: 2,352, Level: 11 Points: 2,352, Level: 11 Points: 2,352, Level: 11
Re: Ateca stands
I was wondering whether somebody can tell me who is the importer of the Ateca Monaco TV stands in the UK.
I saw on some French sites that the Monaco has a 100cm (width) version but could not figure out where I can buy that model in the UK. I have some space limitations so the longer one does not fit but I love the red colour and the style.
Thanks,
zzddrr
Old 21-07-2008, 9:27 PM   #15
2,352, Level: 11
Re: Ateca stands
Nobody knows it? Hmmm, I thought that one of you would know who the impertorer of Ateca stands is in the UK.
Thanks,
zzddrr
Old 15-11-2008, 2:21 PM   #16
2,718, Level: 12
Points: 2,718, Level: 12 Points: 2,718, Level: 12 Points: 2,718, Level: 12
Thanks: Gave 10, Got 16
Re: Ateca stands
Months too late maybe but just found your posting. These stands in three colours are sold by av4homes.co.uk at £239 each
