ekornes
Old 22-11-2007, 11:34 AM   #1
9,526, Level: 23
Points: 9,526, Level: 23 Points: 9,526, Level: 23 Points: 9,526, Level: 23
Thanks: Gave 1, Got 1
ekornes
just a tip for everyone if you fancy Ekornes chairs or sofas and something I learnt recently after pumping some dealers. Ekornes often have returned stock or cancelled orders and dealers should have access to this list. Some items are brand new, others are returned and fixed and you can get between12.5% and 35% discount on them :D Of course it's pot luck what colour combinations they have but I wasn't fussed by this for the cinema room.
The other bonus is that they are not subject to a 10-12 week delay and are just a matter of being delivered from Ekornes UK to the dealer, then you.
I also found that some larger dealers do have their own ex-floor stock and with bigger department stores having to make room for Christmas displays that is also worth a call. I was offered a 3 piece sofa at 40% discount, ex-stock. Just wasn't the model I was after
