Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
low entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Mercury TV entertainment unit
 More...Prices updated November 24th at 8:30am and include delivery.
Are these compatible? (Panny Plasma and Stand) Scotty Boy Plasma Televisions 10 20-10-2004 7:15 PM
Old 19-11-2007, 11:00 AM   #1 (permalink)
Thanks: Gave 38, Got 59
Stand for a 50" panny plasma - What do you think?
Sound Style ST310 Silver
the only issue i have is that the panny is black so a black stand would complement it more. do you think this would suit it, its a good prime imho.
Crafted from finest steel, cut with laser precision and seamlessly fused the ST310 is an extremely rigid and effective support system. The ST310 is specially designed to support 4 pieces of equipment and a centre speaker. The top shelf can easily accommodate the latest large flat screen televisions (up to 95 kilos/165lbs).
Ultra rigid seamless welded frame for optimum performance.
Precision laser cut thick section box section steel.
Attractive lacquered epoxy powder coated frames.
Range of co-ordinated 6mm toughened safety glass shelves to BS Standards. Extra height shelves to accommodate a centre speaker or larger AV amplifiers.
Supplied with height adjustable high performance sound isolation spikes and a castor kit for more conventional furniture requirements.
Usual price: £399.00
Special Price: £179.99
acid007 is online now   Reply With Quote
Old 19-11-2007, 4:07 PM   #2 (permalink)
Thanks: Gave 926, Got 472
Re: Stand for a 50" panny plasma - What do you think?
I like those and the green/aqua glass. And for £179 it`s a bargain. You could always check out your local car spray shop to get a quote on getting it sprayed up black too.
(((Flickr)))
Paulie-W is offline   Reply With Quote
Old 19-11-2007, 10:02 PM   #3 (permalink)
Thanks for your comment paulie, i'm still unsure need to search around a bit more to satisfy myself its going to be ok.........
panny, plasma, stand for a 50
