Does anyone have the Ebuyer Vistron stand?
Old 08-09-2007, 7:40 AM   #1
Sun Sun is offline
4,825, Level: 16
Points: 4,825, Level: 16 Points: 4,825, Level: 16 Points: 4,825, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 20, Got 9
I'm still trying to source a stand and this is obviously a bargain
http://www.ebuyer.com/customer/produ...duct_uid=98233
what I need to know though is whether 2 full size AV items of 44cm wide each can sit next to eachother on one shelf.
Also is it definitely 40cm deep as my amp is 42cm.
Would really appreciate anyone that has one giving me some measurements.
Sun
Old 09-09-2007, 5:07 PM   #2
3,903, Level: 14
Points: 3,903, Level: 14 Points: 3,903, Level: 14 Points: 3,903, Level: 14
Thanks: Gave 1, Got 7
Re: Does anyone have the Ebuyer Vistron stand?
Sun
I've got the exact same stand so:
In answer to your first question, you can fit 2 items side by side but you're likely to have problems with any connections at the back as the rear legs are only ~70cm apart. Short answer = no.
Second question - it's exactly 40cm deep, but I doubt you're even reading this far because of the first issue.
I tried putting an Onkyo 605 and a Humax 9200PVR on one shelf, but half the connections on the back of the Onkyo get blocked by a back leg.
Sun (09-09-2007)
Old 09-09-2007, 6:58 PM   #3
Sun Sun is offline
4,825, Level: 16
Activity: 0.8%
Jwruk, thanks very much for a very concise answer, a dissapointing outcome but you've saved me wasting the cash now, much appreciated.
Now to continue to ridiculously difficult search for a rack, it's harder than buying the kit!
Sun
