New TV Unit help!!!
Old 07-09-2007, 7:38 AM   #1
Greg's Avatar
38,945, Level: 48
Points: 38,945, Level: 48 Points: 38,945, Level: 48 Points: 38,945, Level: 48
Activity: 64.2%
Activity: 64.2% Activity: 64.2% Activity: 64.2%
Thanks: Gave 178, Got 1,399
New TV Unit help!!!
I am desperately trying to find a TV Unit that matches the drawing below.
Not fussed about the material colour, probably maple or some similar light wood. Ideally quite thick though like the Ikea units, maybe 1 1/2" thick wood to take the weight. Or even something in glass would do.
It doesn't have to exactly fit those dimensions so anything close will do.
Greg
Old 07-09-2007, 8:47 AM   #2
4,532, Level: 15
Points: 4,532, Level: 15 Points: 4,532, Level: 15 Points: 4,532, Level: 15
Thanks: Gave 7, Got 5
Re: New TV Unit help!!!
they're pretty precise dimensions, why dont you price up getting it made to your spec.
Old 07-09-2007, 9:16 AM   #3
Greg's Avatar
38,945, Level: 48
Activity: 64.2%
They are precise dimensions but I did say in my post it anything similar will do.
