Wall Mounted Speaker Brackets
| | Post Reply |
| | #3 |
| Prominent Member | Re: Wall Mounted Speaker Brackets Last edited by Paulie-W; 05-09-2007 at 4:49 PM. |
| Quote |
| | #6 |
| Member | Re: Wall Mounted Speaker Brackets Last edited by motr; 06-09-2007 at 11:31 AM. |
| Quote |
| | #16 |
| Member | Re: Wall Mounted Speaker Brackets |
| Quote |
| Thanks from: | gazzared_typer (10-11-2007) |
| | #20 |
| Prominent Member | Re: Wall Mounted Speaker Brackets |
| Quote |
| Post Reply |
I would just look at your room and decide for yourself. If you liked the sound from when they were on stands put them about the same etc. I don`t think there`s any real rule.
I assume that's the screw holes?
E. & O.E.
LinkBack URL
About LinkBacks
