Gale VETRO
Old 30-08-2007, 5:25 PM   #1
5,828, Level: 18
Points: 5,828, Level: 18 Points: 5,828, Level: 18 Points: 5,828, Level: 18
Thanks: Gave 5, Got 361
Gale VETRO
Does the Gale Vetro have underside metal support, or does the glass slide into the column? Have to wonder how much weight it'll support before the glass would shatter
http://www.uptownaudio.com/Gale/Gale_Vetro_rack_2.jpg
Old 31-08-2007, 12:11 PM   #2
2,726, Level: 12
Points: 2,726, Level: 12 Points: 2,726, Level: 12 Points: 2,726, Level: 12
Thanks: Gave 3, Got 3
Re: Gale VETRO
the glass slides into the metal upright with a plastic support underneath. I personally wouldnt put anything too heavy on one of these such as a home cinema amplifier ie marantz sr4001 for example
Old 31-08-2007, 12:14 PM   #3
5,828, Level: 18
Re: Gale VETRO
I have Audiolab 2 channel poweramps, but it'll just have one at the bottom, and a DVD player, plus a Lexicon MC-1 if existing cables are long enough, and a 17" PC monitor LCD.
Alternative is Soundstyle Z5, as that's around the same width (very limited and those two will be a tight squeeze)
