White Samsung stand required... help!
Old 28-08-2007, 9:16 AM   #1
ace_brodie's Avatar
3,486, Level: 13
Points: 3,486, Level: 13 Points: 3,486, Level: 13 Points: 3,486, Level: 13
Thanks: Gave 78, Got 27
Question White Samsung stand required... help!
Hi all
I’m due to take delivery of the new Samsung LE32R86WDX, which is one of the white ones. This is for the bedroom. I am looking to by a table or a stand for the LCD. The sammy will at the foot of the bed. I am, therefore looking for a table or stand which is long, narrow and sits about 600mm high. Ideally the TV will be the only thing that would sit on top and my sky+ and dvd player can sit underneath. Cable managements would also be good. They unit needs to be white. Also, it needs to have a slightly classic look… ie not too modern. The only thing I have seen to date is this. But its too tall, the top is part glass and the storage underneath needs a bit more height.
So, if you have any suggestions, I would be delighted to hear them
Many thanks
Andy
Old 30-08-2007, 12:19 PM   #2
ace_brodie's Avatar
3,486, Level: 13
Re: White Samsung stand required... help!
So, in the end, i went for the Ikea one... felt i could live with its small problems.
Gonna knock it up tonight and will upload some pics once its all done!
Andy
