23-08-2007, 10:09 AM
#1 (permalink)
| | Ex Member
Thanks: Gave 5, Got 362 | Ikea Oppli
Are there any units that are identical to the Ikea Oppli, but more "open" it's the perfect width, depth & height but my components get a bit warm inside.
20-09-2007, 12:50 PM
#2 (permalink)
| | Member
Thanks: Gave 68, Got 17 | Re: Ikea Oppli Quote:
Originally Posted by badbob Are there any units that are identical to the Ikea Oppli, but more "open" it's the perfect width, depth & height but my components get a bit warm inside. | i am looking for something similar to
20-09-2007, 3:03 PM
#3 (permalink)
| | Member
Thanks: Gave 7, Got 5 | Re: Ikea Oppli
Dont see how it's possible - if you want the same dimensions, it's already and open front and back... short of drilling holes in the top and bottom!!!
20-09-2007, 3:26 PM
#4 (permalink)
| | Ex Member
Thanks: Gave 5, Got 362 | Re: Ikea Oppli
The units are a incredibly tight fit, with zero airflow on the sides. So something similar with poles on each shelf strut would be ideal. ie Apollo Aria in 1.5m form
20-09-2007, 3:26 PM
#5 (permalink)
| | Member
i just want to find one like it
they are discontinued now
21-09-2007, 3:32 PM
#6 (permalink)
| | Member
Thanks: Gave 7, Got 14 | Re: Ikea Oppli
Lookat the new "Oppli", the Ikea Besta - also has the advantage of lots of different sizes and can be fitted with doors and drawers for DVD's etc.
I just bought two of the 120 x 38 x 40 units in black/brown fitted four black/brown doors with frosted glass and legs. Left the back panel off the two central doors where the equipment is going.
All for under £150, remotes work through the frosted glass by the way.
1) Panny TH-42PX80 / Amstrad Sky+HD / Panny DMR-EX75 / JVC TH-V70R / Thommo DHD4000 / Tosh HD-EP30
2) Sammy 26LE74 / Tosh SD-42 / Topfield TF5800 / Panny DVD-S27
3) Tosh 32ZD26 / Tosh V753 VCR / Fusion FVRT200 / Panny DMR-E85 / Old Sky Box for Freesat
21-09-2007, 3:39 PM
#7 (permalink)
| | Member
Originally Posted by Tellyfiend Lookat the new "Oppli", the Ikea Besta - also has the advantage of lots of different sizes and can be fitted with doors and drawers for DVD's etc.
All for under £150, remotes work through the frosted glass by the way. |
thanks will have a look for one and see, don't think it will be wide enough at 120, my space is about 150 which was ideal for the oppli
have you got a direct link to the ones you bought, was it this? http://www.ikea.com/gb/en/catalog/products/20102149
21-09-2007, 4:17 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 159, Got 53 | Re: Ikea Oppli Quote:
Originally Posted by techmob i just want to find one like it
they are discontinued now | Sort of but not entirely, it would appear ... http://www.ikeaplus.co.uk/index.php?...cl1=98&cl2=213 |
21-09-2007, 4:25 PM
#9 (permalink)
| | Member
Originally Posted by tausifs |
thats better |
21-09-2007, 6:08 PM
#10 (permalink)
| | Prominent Member
Thanks: Gave 919, Got 472 | Re: Ikea Oppli Quote:
Originally Posted by techmob thats better  |  Delivery aint cheap.
22-09-2007, 10:40 AM
#11 (permalink)
| | Member
Thanks: Gave 7, Got 14 | Re: Ikea Oppli Quote:
Originally Posted by techmob | Yes it was, why not add on one of these to make it 180, if you've room (I used 2 x 120 units) http://www.ikea.com/gb/en/catalog/products/80102146
22-09-2007, 11:01 AM
#12 (permalink)
| | Member
Originally Posted by Tellyfiend | i don't have the room unfortunatly
11-10-2007, 7:04 PM
#13 (permalink)
| | Member
Thanks: Gave 13, Got 4 | Re: Ikea Oppli Quote:
Just what Im after, it all seems well and good but did you click on the service charge? Quote:
Why do I have to pay £10.00 to use the service?
The £10.00 charge is to cover our administrative expenses, including paying the shopping assistants to go buy the products from the store and arrange delivery, it also includes the fees we pay to process credit and debit card transactions.
| But Ikea stores dont do this model anymore ?????
