| Help..what av stand fits an htm7 and a plasma?
Anyone know of an av stand which would fit a chunky av amp sided with dvd cd and skybox(stacked around 30 cm) on the bottom shelf.
an htm7 on the middle shelf....its at least 30 cm tall
and take a 40 inchish flat screen on a ped on top....
or a two shelf setup with a intergrated panel support that leaves enough clearance for the htm7 and the bottom of screen.
I cant mount the tv on the wall due to it being an internal stud frame with stairs behind it.
Been looking around and think i can do it for around a 800 using some atacama seperates but aint got half that budget!!!
