fitting my 50" sammy to a stud wall
Old 05-08-2007, 8:33 AM   #1
5,139, Level: 16
Points: 5,139, Level: 16 Points: 5,139, Level: 16 Points: 5,139, Level: 16
Thanks: Gave 2, Got 1
We've just moved home and my plasma needs to be mounted to a stud wall. This is somthing i've never done before as previously its been mounted to solid plaster/breze block/brick walls.
I just purchased a stud detector and had a little play getting it to beep on the wall studs however I am still afraid as to wether 2 studs are enough to secure the weight of my plasma.
I read that studs vary in width apart from 16 to 24 inches, but are they usually of sufficient strenghth to hang a 50" plasma to?
Does anyone have any tips?
Old 05-08-2007, 8:37 AM   #2
noidea's Avatar
5,069, Level: 16
Points: 5,069, Level: 16 Points: 5,069, Level: 16 Points: 5,069, Level: 16
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 103, Got 68
Re: fitting my 50" sammy to a stud wall
it should hang on 2 studs easily
Old 05-08-2007, 9:20 AM   #3
6,433, Level: 19
Points: 6,433, Level: 19 Points: 6,433, Level: 19 Points: 6,433, Level: 19
Thanks: Gave 183, Got 64
agree... 2 studs is fine, but make sure you hit the centre of the stud, and use good fixings. When i did mine, i ended up cutting out a small bit of the wall, just to confirm the locations by eye, then plumb a line... simply filled the holes afterwards (made sure they were behind the screen anyway)
