| Suggestions for a TV stand, no more than 40cm high, 120cm wide
Hello,
I have a slightly irritating setup at the moment where the 5.1 is setup for my projector, the screen pulls down in front of the bay window. However annoyingly my existing CRT is in the corner of the room to the right of the bay as the CRT and stand blocked out too much light. I've now got a Toshiba 37" LCD and as we watch more TV than projector I really need to return it to the bay window to make the most of my 5.1.
What I need is a nice low TV stand, I guage arround no more than 40cm in height but not so wide that you can't get to the window, so 120cm max and ideally closer to 100cm. The TV height on a stand I need to accomodate is 66cm. I need to be able to fit an an amp, dvd player, cd player, sky box and ideally space for the xbox
I considered a Lack or Oppli but they're just too wide, the Argos Stella is all I have found so far that's reasonable but it's not a style exactly to my likeing. All the ebuyer ones are too high, I can't really justify more than about £100 either.
Any know of anything suitable?
Mat
