Cabinet for 46" Flat TV wich will also hold CDs?
Old 25-07-2007, 4:39 PM   #1
4,115, Level: 15
Points: 4,115, Level: 15 Points: 4,115, Level: 15 Points: 4,115, Level: 15
Thanks: Gave 4, Got 3
I'm looking for a contemporary, stylish cabinet that is quite low and which can house several hundred CDs (preferable in draws) - and on which my new TV can sit nicely - any suggestions?
Old 29-07-2007, 1:22 PM   #2
nismosteve
Posts: n/a
Re: Cabinet for 46" Flat TV wich will also hold CDs?
I had a similar problem last year trying to find something that would fit my gear into, especially my centre speaker. I gave up in the end as all the units had resorted to shelves that were about 130mm high and wouldn't fit my centre speaker or any of the other gear I had.
In the end I made it myself out and had to make it a bit higher than I originally wanted. It is made out of 30mm mdf and sprayed mat black, it came out pretty good - well atleast as good as the shop ones anyway!
It measures 1550L X 800 H X 600 D, shelf opening for centre is 500 L X 200 H.
Fine for a 60" plasma some time in the future.
It has cd storage in the drawers as well as CD/DVD storage at each end, the red leather boxes also hold dvds.
May not be what you are looking for but ...
Old 29-07-2007, 7:26 PM   #3
3,219, Level: 13
Points: 3,219, Level: 13 Points: 3,219, Level: 13 Points: 3,219, Level: 13
Thanks: Gave 36, Got 224
I have this cabinet, it has two large draws on one side. I got the black version
http://www.go-electrical.co.uk/view/...ption/ref/3190
John.
