Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
John Lewis Maharani Corner TV Unit
John Lewis Stowe TV Unit
John Lewis Matilda Bar Chair, Black
The Furniture Factory Worcester TV En...
Ellis Entertainment Unit, Light
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
 More...Prices updated November 22nd at 4:30pm and include delivery.
Old 23-07-2007, 11:00 PM   #1 (permalink)
Thanks: Gave 21, Got 3
customising a stand?
I am thinking of buying either of these
http://www.fyhl.co.uk/store/product_...oducts_id/1974
http://www.fyhl.co.uk/store/product_...oducts_id/1970
Any ideas if it will be possible to add an extra shelf by having a new glass
created and then adding it in with supports?
The glass i will go for will probably be black - any idea how much it might cost?
mo786 is offline   Reply With Quote
Old 25-07-2007, 8:33 AM   #2 (permalink)
AMc
Thanks: Gave 10, Got 28
Re: customising a stand?
I'd be very surprised if you could do it and have it look as good - let alone be strong enough with the glass providing the structural stability.
You might be able to combine two sets of parts to make another shelf but
If I were you I would keep looking for a unit that has enough shelves by design.
My Flickr Pictures
Philips Bogart DLP Projector-Sony KV32FX60U-Thomson Tivo-Wharfedale DV832BN(2) Freeview-Toshiba SD330E DVD-
-B-Tech Quintro+-Denon 2105 receiver-Canton CD1+CD50+CD100 Playstation3-Philips Pronto
AMc is offline   Reply With Quote
Old 25-07-2007, 12:48 PM   #3 (permalink)
Thanks: Gave 3, Got 26
As a diy I wouldnt even bother. If its a uk made product you could ask the manufacturers if they could supply the additional componants, otherwise as AMc says look for something else
TagMclaren DVD32FLR TAg AV32Rbp+psm Tag 100x5 power amp, Wilson Benesch Arcs, Tag Calliope centre. Velodyne CH10T sub, Loewe Connect 42+DR TV
davee is offline   Reply With Quote
Old 25-07-2007, 2:29 PM   #4 (permalink)
I asked the manufacturer but (As expected) they said they wouldnt do it as they wont have tested it it the extra weight - the extra weight is just for a light VCR and I am sure that it would support all 3 of my units - esp as i am NOT putting my TV on top of it.
customising, stand
