frustrated cabinet search
Old 03-05-2007, 5:59 AM   #1
UnicronI
Posts: n/a
Some one help!
Been looking for a corner beech unit for a 40 - 42" TV to hold av amp, xbox, xbox 360, wii, virgin box & ps2 ( center speaker if possible too)
Can't say i've seen anything that fits that criteria............for any price.
at my wits end with this
Old 03-05-2007, 6:13 AM   #2
GrahamC's Avatar
8,737, Level: 22
Points: 8,737, Level: 22 Points: 8,737, Level: 22 Points: 8,737, Level: 22
Thanks: Gave 17, Got 71
Re: frustrated cabinet search
www.eatsleeplive.co.uk sponsors of this very forum can make to your exact requirements.
Old 03-05-2007, 6:34 AM   #3
Illustrious Member
Abbeygoo's Avatar
19,858, Level: 34
Points: 19,858, Level: 34 Points: 19,858, Level: 34 Points: 19,858, Level: 34
Activity: 10.5%
Activity: 10.5% Activity: 10.5% Activity: 10.5%
Thanks: Gave 1,937, Got 2,085
Pretty good selection here
Old 06-05-2007, 9:24 AM   #4
UnicronI
Posts: n/a
cheers folks. alas my search goes on!
Old 06-05-2007, 9:30 AM   #5
Battlestar's Avatar
22,924, Level: 36
Points: 22,924, Level: 36 Points: 22,924, Level: 36 Points: 22,924, Level: 36
Thanks: Gave 213, Got 183
Is this any good?
http://www.ikea.com/webapp/wcs/store...umber=70045482
Old 06-05-2007, 8:34 PM   #6
UnicronI
Posts: n/a
Much closer ta mate. just need to know the width of each side of the shelves.
Any1 got this unit?
Old 07-05-2007, 9:50 PM   #7
3,667, Level: 14
Points: 3,667, Level: 14 Points: 3,667, Level: 14 Points: 3,667, Level: 14
HI THERE
I was in a similar situation to you, i couldnt find anything to fit and i really did not want glass and chrome.So in the end i had one made to my own specifications so everything fits perfectly and the design is my own.
mine is made from kiln dried oak which is expensive an very heavy,it cost me £360 which i would have had to pay for a glass and chrome job anyway.
the cheapest way to do it is to find a pine furniture maker have it made to your own spec and stained whatever colour you want.
it was one of the best decisions i ever made
Mickyh
Old 08-05-2007, 9:44 AM   #8
inzaman's Avatar
22,360, Level: 36
Points: 22,360, Level: 36 Points: 22,360, Level: 36 Points: 22,360, Level: 36
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 126, Got 544
Mickyh, do you have any pictures you can post as it sounds interesting
Old 08-05-2007, 10:18 AM   #9
3,667, Level: 14
hi Inzaman
i will post a picture tonight as i am at work now.
Old 08-05-2007, 7:40 PM   #10
3,667, Level: 14
here is a pic of my table i had made in oak ,sorry pic quality not very good.
Old 09-05-2007, 10:13 AM   #11
inzaman's Avatar
22,360, Level: 36
Activity: 2.4%
Mickyh, that looks very smart Thanks for posting the pic
Old 09-05-2007, 8:57 PM   #12
2,773, Level: 12
Points: 2,773, Level: 12 Points: 2,773, Level: 12 Points: 2,773, Level: 12
Thanks: Gave 21, Got 21
Thanks from me too Mickyh
It's amazing what you can get done if you can find the right person. It looks solid, the colour nice and most of all it's exactly what you wanted it to be. Nice one.
