| 'Riser' for LCD TV?
I have my Toshiba 37WLT66 on a fairly standard 3 tier glass shelved stand (with silver tubular legs). The LCD stands on the top, my DVD player and amp are on the 2nd shelf, and my xbox and 360 are on the bottom shelf.
I used to have my centre speaker from the surround system sitting on the top shelf in front of the TV, but found that it blocked the signal from the remote. Now it sits on top of the xbox, which doesn't look good and I'm sure isn't great for sound quality.
So, what I'd like to find is some sort of 'riser' (like the sort of thing an office PC user might use to lift a monitor to the correct working height), but something that would match a glass/silver AV stand. Then I could have the centre speaker back in front of the TV but it would be lower and wouldn't block the signal.
I was in John Lewis at the weekend, and they had some AV units/stands made entirely from formed perspex (about 15mm thick), but the smallest one was about 2 DVD players wide, too wide for what I want.
Anyone know where I could get such a thing?
