Ikea Blackout Blinds
Old 18-04-2007, 12:27 PM   #1
HDPete's Avatar
4,830, Level: 16
Points: 4,830, Level: 16 Points: 4,830, Level: 16 Points: 4,830, Level: 16
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 25, Got 10
Question Ikea Blackout Blinds
Whilst at the annual Ikea visit last week, I noticed that they are now selling Blackout blinds in widths up to 2m. The product name escapes me now, but they were rediculously cheap, were in various widths, various colours and promised to black out 100% of light.
My viewing is on a projector in the lounge to keep a reasonable balance of WAF. However, even SWMBO has suggested making it a little darker for daytime HD viewing and she was impressed with the Ikea ones.
Before comitting to buying them though, I'd thought I'd poll peoples opinions of them here - good or bad - has anyone any experience that they'd like to share?
Many thanks in advance.
Pete
Old 18-04-2007, 12:58 PM   #2
3,542, Level: 13
Points: 3,542, Level: 13 Points: 3,542, Level: 13 Points: 3,542, Level: 13
Re: Ikea Blackout Blinds
I know which ones you're talking about, I mounted one behind a wooden blind so that when rolled up you can't see the roller blind behind the wood mechanism. When rolled down it provides a very good amount of light blocking. Not 100%, there's some light bleeding in at the sides where I guess it could be down to how i've fitted it, but they're very good considering I paid around 15 pounds for it.
Old 18-04-2007, 1:16 PM   #3
HDPete's Avatar
4,830, Level: 16
Activity: 1.0%
Thanks very much - good to hear. What colour did you go for?
Old 18-04-2007, 1:23 PM   #4
3,542, Level: 13
I went for white, I use it to block out glaring sun in the mornings where both wooden blinds and curtains together didn't do the trick. So when I use it its night and I cant say i notice the colour and during the day its rolled up so you can't see it at all. Saying that when I bought it, they only had white or a dark blue that wouldn't go. Considering the costs of similar blinds, don't think you can go wrong by trying it.
Old 18-04-2007, 2:21 PM   #5
7,081, Level: 20
Points: 7,081, Level: 20 Points: 7,081, Level: 20 Points: 7,081, Level: 20
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 125, Got 22
I use a white one in my daughters bedroom and a dark blue one in my media room - both do a cracking job for not-a-lot of money.
Sheks
Old 18-04-2007, 2:59 PM   #6
HDPete's Avatar
4,830, Level: 16
Activity: 1.0%
Thanks both!!
I don't suppose that you remember the scandinavian name of the blinds so I can look them up on the web site and check stock levels do you...?
Old 18-04-2007, 3:26 PM   #7
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
Moved to furniture etc
Old 18-04-2007, 6:46 PM   #8
HDPete's Avatar
4,830, Level: 16
Activity: 1.0%
Thumbs down Re: Ikea Blackout Blinds
Your choice of forum location is interesting....
Black out blinds are neither Stands, Cabinets, Seating or Furniture. The original location of DIY was more appropriate.
Old 18-04-2007, 7:13 PM   #9
furs307c's Avatar
3,081, Level: 13
Points: 3,081, Level: 13 Points: 3,081, Level: 13 Points: 3,081, Level: 13
Thanks: Gave 0, Got 12
I used one of these as a projector screen for a projector i had but had to sell seemed ok to me but was only a cheap projector.
Old 19-04-2007, 12:28 PM   #10
inzaman's Avatar
22,352, Level: 36
Activity: 2.7%
Why, are you planning on making them
Old 19-04-2007, 5:22 PM   #11
8,396, Level: 21
Points: 8,396, Level: 21 Points: 8,396, Level: 21 Points: 8,396, Level: 21
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 137, Got 267
They are called 'Tupplar' or 'Tupplur'.
I used one as a temporary screen and it worked brilliantly. I now use one to block out a patio window and it works flawlessly.
Old 19-04-2007, 11:34 PM   #12
SeedyR's Avatar
13,609, Level: 28
Points: 13,609, Level: 28 Points: 13,609, Level: 28 Points: 13,609, Level: 28
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 357, Got 478
They're called Tupplur:
http://www.ikea.com/webapp/wcs/store...roductId=49066
Old 29-04-2007, 11:07 PM   #13
Navvie's Avatar
2,227, Level: 10
Points: 2,227, Level: 10 Points: 2,227, Level: 10 Points: 2,227, Level: 10
Activity: 1.0%
Thanks: Gave 30, Got 24
I picked up a blackout blind from Argos... Ikea is miles and miles and miles away, and as such I'm not in their delivery area.
This is the blind I got...
http://www.argos.co.uk/static/Produc...er/1201602.htm
It blocks 100% of sunlight through the blind itself, but allows some to come in down the edges.
I mounted it behind a venetian blind, so when its rolled up, you can even see it.
Old 30-04-2007, 9:27 AM   #14
jonny round boy's Avatar
8,448, Level: 21
Points: 8,448, Level: 21 Points: 8,448, Level: 21 Points: 8,448, Level: 21
Thanks: Gave 0, Got 13
I've had 2 of these Ikea ones for about 2 years, IIRC.
They're both 1.8m wide, and block out an awful lot of light, but there is one problem with them - over that width they sag slightly in the middle. Not a big problem, but over time it causes slight creasing in the centre. They were fine for a few months, but steadily the creasing caused damage to the coating as it was rolled up & down. This leaves small pin-pricks of light in a line down the centre. These have slowly got worse & worse. I've taken a picture to illustrate the problem.
HTH
BTW - ignore the holes along the bottom edge - those were caused by the cat!
nero0410 (20-06-2007)
Old 09-05-2007, 3:57 PM   #15
19,160, Level: 33
Points: 19,160, Level: 33 Points: 19,160, Level: 33 Points: 19,160, Level: 33
Thanks: Gave 10, Got 58
I'm thinking of getting a couple of these for our bedroom window as the light is spoiling the picture on our LCD TV now its wall mounted. Does anyone know if they can be cut to size?
Old 09-05-2007, 5:46 PM   #16
3,301, Level: 13
Points: 3,301, Level: 13 Points: 3,301, Level: 13 Points: 3,301, Level: 13
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 108, Got 204
If you click that Argos link it says they are easily trimmed to size.
Old 09-05-2007, 6:54 PM   #17
19,160, Level: 33
Thanks. Just checked and the argos ones don't come in the right sizes as I've got a window thats 2.7m wide. So I'm looking at a 2m + an 80cm one from ikea. I've priced a custom made 2.7m blind at about £60 but would actually prefer 2 blinds as the small one will cover the part of the window that opens which is convenient.
Anyone know if the ikea one can be trimed?
Old 09-05-2007, 9:14 PM   #18
3,306, Level: 13
Points: 3,306, Level: 13 Points: 3,306, Level: 13 Points: 3,306, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 31, Got 65
We just got 2 of these blinds at the weekend from ikea, and although not fitted yet, i have just been browsing the instructions and yes they can be trimmed to size !
Bassbin (09-05-2007)
Old 09-05-2007, 9:40 PM   #19
19,160, Level: 33
Smasing. I'll have to call in and get some. Cheers.
Old 22-09-2009, 10:43 AM   #20
2,291, Level: 11
Points: 2,291, Level: 11 Points: 2,291, Level: 11 Points: 2,291, Level: 11
Activity: 17.0%
Activity: 17.0% Activity: 17.0% Activity: 17.0%
Thanks: Gave 1, Got 1
hi, i am looking for a black out blind for my home cinema room. the blind need to be able to black out day light and street light but after few search i have notice that there is lots of love for the ikea tupplur blackout blind. the question is : are these blinds really good ?. In this same thread i have notice that some 1 bought a blind from argos but is it any good. the last thing is that the colour of my cinema room is white mist so can people recommend what blackout blind colour will match the white mist colour of my room.
