Best Clearance
Old 07-04-2007, 6:56 PM   #1
sjp1966's Avatar
4,914, Level: 16
Points: 4,914, Level: 16 Points: 4,914, Level: 16 Points: 4,914, Level: 16
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 12, Got 3
Best Clearance
For some time now my AV Kit has sat in a nasty looking MDF cabinet, mainly because i cannot find a stands to support my AMP. The reason for that is that i am not sure what clearance i shoul dhave between the top of the AMP and the bottom of the shelf above it.
My AMP is a Harmon Kardon AVR7300, according to the manual it is 192mm heigh. the total usable space of the shelf it is on is 300mm, gving it a tad over 100mm clearance between the top of the amp and the next shelf.
The AMP runs pretty hot and i am figuring that the more space the better, but i have been looking at High AV 10 from Stands Unique [http://www.standsunique.com/productr...hifi/av10.htm] but at anything from between £470 and £570 i think that it is very expensive.
Can anyone provide give me an idea of what the best gap i should have between amp and shelf in order to give better airflow. I know the cabinet at the moment is enclosed whereas the high AV10 isnt, so would i be right in thinking that the gap could be less?
Old 07-04-2007, 7:51 PM   #2
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Points: 43,239, Level: 50 Points: 43,239, Level: 50 Points: 43,239, Level: 50
Activity: 90.9%
Activity: 90.9% Activity: 90.9% Activity: 90.9%
Thanks: Gave 466, Got 1,875
Re: Best Clearance
I'd suggest you just get anything with a gap of around an inch, as long as it's open.
The fact that your present one is enclosed is a killer, IMO.
My Denon is like a toaster when run at very moderate levels, but it's not a concern to me, that's how they are.
My Yam 557 was always cool, but with the puny power, I wouldn't expect anything else
Your HK is fairly meaty, so it will probably run hot.
Again, that's the way it is.
Put it in an open stand and all will be fine, IMO
Old 08-04-2007, 11:49 AM   #3
sjp1966's Avatar
4,914, Level: 16
Activity: 0.7%
Re: Best Clearance
really, only 1 inch. wow that is surprising, although if right it will make my life a lot easier, and yes the next unit will be open so will have vetter airfor. the current unit is enclosed on three side, but with no dorr the hot air escapes that way.
Thanks for the advise
Old 08-04-2007, 12:19 PM   #4
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Re: Best Clearance
Make certain that proper space is provided both
above and below the unit for ventilation. If this
product will be installed in a cabinet or other
enclosed area, make certain that there is sufficient
air movement within the cabinet. Under some circumstances,
a fan may be required.
Pulled from your manual.
A bit vague really, but pretty typical.
I look at it that you only have a very small gap underneath, so shouldn't need a large gap above, as long as the air is free to move, which it would be
Old 08-04-2007, 7:26 PM   #5
Knightshade's Avatar
11,666, Level: 25
Points: 11,666, Level: 25 Points: 11,666, Level: 25 Points: 11,666, Level: 25
Thanks: Gave 13, Got 51
Re: Best Clearance
Agreed, an inch is about right. An open unit will make a lot of difference to the temperature. If you don't have to bother about little fingers Hi Fi is so much easier.....
Old 08-04-2007, 7:56 PM   #6
mhuk05's Avatar
14,581, Level: 29
Points: 14,581, Level: 29 Points: 14,581, Level: 29 Points: 14,581, Level: 29
Thanks: Gave 31, Got 128
Re: Best Clearance
The more space the better.
I would never put mine on a shelf with only 25mm clearance, even if it was open.
Old 08-04-2007, 8:14 PM   #7
11,666, Level: 25
Re: Best Clearance
No harm in it whatsover, wouldn't recommend it with valve amps though.
Old 08-04-2007, 10:01 PM   #8
Illustrious Member
Badger0-0's Avatar
43,239, Level: 50
Activity: 90.9%
Re: Best Clearance
Well, the former goes without saying
The latter, well I was going to go into a big useless rant about valves, but decided against
I'll stand by the inch
