Mega AV stand required!
Old 01-04-2007, 5:00 PM   #1
5,427, Level: 17
Points: 5,427, Level: 17 Points: 5,427, Level: 17 Points: 5,427, Level: 17
Thanks: Gave 1, Got 0
I intend to house the following units in an AV stand:
AV Receiver
Sky HD Box
DVD/Video player
Blueray Player
HDDVD player
CD player
Sony PS3
Xbox 360
Nintendo Wii
At this rate, I need at least an AV stand that can take 10 AV units.
Any suggestions? Prefer a 4-5 rack stand, that I can put each unit side by side.
Thanks.
Old 01-04-2007, 5:07 PM   #2
ninehours's Avatar
9,599, Level: 23
Points: 9,599, Level: 23 Points: 9,599, Level: 23 Points: 9,599, Level: 23
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 130, Got 100
Re: Mega AV stand required!
http://www.progressive-av.com/furnit...300_series.htm You could possibly put the Ps3 360 and Wii upright next to each other in the centre speaker place? also i have been told by Liam at Progressive that these are about to be discontinued.
Old 01-04-2007, 5:09 PM   #3
5,427, Level: 17
prefer an open glass unit, where you can see all the units.
Old 01-04-2007, 5:11 PM   #4
ninehours's Avatar
9,599, Level: 23
Activity: 1.4%
Take the doors of
Old 01-04-2007, 10:35 PM   #5
7,729, Level: 20
Points: 7,729, Level: 20 Points: 7,729, Level: 20 Points: 7,729, Level: 20
Thanks: Gave 151, Got 76
i've got an apollo mezzo soprano rack. its glass with a processor, power amp, vcr, dvdr, dvd player, ntl box and an xbox 360 on it. its areally nicce design (imo) and modular so u can add to it. the only downside with glass racks is how to hide the cables at the back - anyone got any bright ideas cos its looks a mess as much as i try =
Old 02-04-2007, 7:54 AM   #6
Conspicuous Member
Crustyloafer's Avatar
32,639, Level: 44
Points: 32,639, Level: 44 Points: 32,639, Level: 44 Points: 32,639, Level: 44
Activity: 22.7%
Activity: 22.7% Activity: 22.7% Activity: 22.7%
Thanks: Gave 201, Got 1,227
Something like this might do the trick from Spectral Furniture.
http://www.spectral-moebel.de/
Alternatively the Stands Unique Ultimate AV Rack would work well too.
http://www.standsunique.com/productr...i/ultimate.htm
Old 02-04-2007, 5:08 PM   #7
Blueforest
Posts: n/a
Many thanks for the valuable information. I shall give it a try.
Thanks again for your time!
Old 02-04-2007, 9:06 PM   #8
5,325, Level: 17
Points: 5,325, Level: 17 Points: 5,325, Level: 17 Points: 5,325, Level: 17
Thanks: Gave 0, Got 2
Originally Posted by jasonuk View Post
Any suggestions?
Get one made! Any good woodworker will be able to knock something up to your exact specs in your chosen wood!
Here's a pic of mine!
Old 03-04-2007, 4:51 PM   #9
4,893, Level: 16
Points: 4,893, Level: 16 Points: 4,893, Level: 16 Points: 4,893, Level: 16
Thanks: Gave 5, Got 42
I use a sideboard and two tall cabinets to house all my av gear (about 40 units - amp,several Tivos, xboxes, wii, ps3, dat, skyhd boxes,hd dvd, media centre etc.).
I guess you could have them custom made from Jali.co.uk or your local cabinet maker.
Old 03-04-2007, 6:22 PM   #10
5,325, Level: 17
Pics please Cyril!! I gotta see it! 40 units? Then I can show the Mrs, show her what I aspire to!
Old 05-04-2007, 9:29 PM   #11
4,725, Level: 16
Points: 4,725, Level: 16 Points: 4,725, Level: 16 Points: 4,725, Level: 16
Thanks: Gave 9, Got 34
I must agree with BigJonnyBravo, have a chat with a local cabinet maker and you will be surprised what can me made at a very good price point.
Take a look at my cabinet that I had custome made.
Get your 360's out for the lads (Don't Quote with Images)
Hope that helps,
pemberto
Old 21-10-2007, 8:24 AM   #12
4,893, Level: 16
Pemberto: where did you get your cabinet made?
I need one about 3 times as big (a wall unit)
Here's one third of my setup:
Old 21-10-2007, 10:02 AM   #13
4,725, Level: 16
I had the cabinet custom made to my own design, by a local cabinet maker, http://www.harmanandsons.com. They are located in Horsham, West Sussex. Its about 20mins west of Gatwick airport.
It was delivered in five sections and put together onsite. All the doors are solid oak and the rest is oak vaneer.
I have only made a couple of changes to the design, none of which are visible. They all concern cable management and power management.
Instead of running multiple power sockets in the wall or multiple extension blocks I used an 11ft MK Electric dado trunking system which contains 11 double unswitch sockets and 8 cat5e sockets. This is then connected on a dedicated switched mains.
Hope that helps,
Pemberto
Old 22-10-2007, 11:16 AM   #14
10,159, Level: 24
Points: 10,159, Level: 24 Points: 10,159, Level: 24 Points: 10,159, Level: 24
Thanks: Gave 63, Got 35
Cyril,
where did you get the sideboard from and is it available in other finishes??
Pemberto - sorry to be cheaky but what was the cost(ish) for your custom made?
Lawrenso
Old 22-10-2007, 12:46 PM   #15
4,725, Level: 16
Lawrenso,
The unit cost me £1100.00 which I still think is great value for money. When I first started looking for a custom unit I was getting quotes from £6500 to £3000.
OK, the carcass is MDF and all the face surfaces are MDF Oak, but the doors are solid oak and they were a real pain to make.
At the end of the day I have a cabinet that I designed, that takes all of my equipment and still gives me a little room for futures.
If you want any more info, just let me know.
Pemberto
lawrenso (23-10-2007)
Old 04-11-2007, 5:13 AM   #16
4,893, Level: 16
Originally Posted by lawrenso View Post
Cyril,
Lawrenso
Habitat Memphis - it's available in white gloss as well. You need to drill holes in the back for cables and perhaps modify the drawers in the centre as well.
If you have less kit, you can get the lower memphis which is designed for AV kit and has holes for cables.
lawrenso (06-11-2007)
Old 23-11-2007, 8:29 PM   #17
5,427, Level: 17
Anyone know of any 4 shelf black gloss stand?
Wide enough for a 46" TV, so i can place 2 units side by side per shelf.
Old 23-11-2007, 9:02 PM   #18
2,438, Level: 11
Points: 2,438, Level: 11 Points: 2,438, Level: 11 Points: 2,438, Level: 11
Thanks: Gave 7, Got 16
Originally Posted by pemberto View Post
Lawrenso,
Pemberto
Seeing as the doors are solid oak i think you got a good deal there! Great to see a custom piece of furniture like that. It looks really good!!!!
Old 23-11-2007, 9:13 PM   #19
4,725, Level: 16
Thanks for the feedback Curature,
Old 29-11-2007, 6:24 PM   #20
3,233, Level: 13
Points: 3,233, Level: 13 Points: 3,233, Level: 13 Points: 3,233, Level: 13
If price dosent worry you, i would suggest looking at Spectral stands and getting an additional cabinet to house other AV equipment. www.firstthingsfirst.de/
