Looking for a curved sofa?
Old 01-04-2007, 3:26 PM   #1
SpencerUp's Avatar
5,869, Level: 18
Points: 5,869, Level: 18 Points: 5,869, Level: 18 Points: 5,869, Level: 18
Thanks: Gave 61, Got 22
Hello, I am currnelt yinterested in purchasing a new sofa although if I can I would prefer to look at getting something a bit different! A curved sofa for example! If any of you know where I can even begin to look for one please let me know here!
Thanks in advance!
Old 01-04-2007, 3:59 PM   #2
ninehours's Avatar
9,599, Level: 23
Points: 9,599, Level: 23 Points: 9,599, Level: 23 Points: 9,599, Level: 23
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 130, Got 100
Re: Looking for a curved sofa?
Found a chair http://dwell.co.uk/product.php?prod=103113 and one sofa that says curved but not sure it's the kind of curved you mean http://www.furniturestar.co.uk/produ...roductid=19312
Old 01-04-2007, 4:20 PM   #3
SpencerUp's Avatar
5,869, Level: 18
Thanks, but looking at more of a U shaped sofa
Old 01-04-2007, 4:58 PM   #4
ninehours's Avatar
9,599, Level: 23
Activity: 1.4%
http://www.slotfurniture.com/u-8st-2.html
Old 02-04-2007, 9:38 AM   #5
45,485, Level: 52
Points: 45,485, Level: 52 Points: 45,485, Level: 52 Points: 45,485, Level: 52
Activity: 21.6%
Activity: 21.6% Activity: 21.6% Activity: 21.6%
Thanks: Gave 378, Got 854
DFS?
We got a corner sofa from there, but usually they are modular. So instead of the normal Left end + corner + flat bit, we got Left end + corner + right end.
If you wanted a U shape, you could then do something like Left end + corner + straight bit + corner + right end.
Pretty flexible really - I'd imagine most sofa places would do similar
