25-03-2007, 11:30 AM
#1 (permalink)
| | Member
Thanks: Gave 7, Got 25 | Low white cabinet needed
I know this is not the "correct" forum but i've tried in other threads with no luck. Perhaps one of you guys can help if you've come across what i want in your builds.
I've just bought a 37" Tosh for the kitchen/conservatory. The kitchen is in white gloss and i'd like to keep this theme with the AV cabinet.
I want to keep it low so the measurements will be c.35cm high, between 54cm and 60cm deep and 150 - 180cm long.
I also prefer not to have any kit on display so it'll need cupboards as opposed to shelves/drawers. I've looked at Dwell, Ilva, Habitat and Ikea and there are some so close it hurts e.g. this one is perfect but has drawers. http://dwell.co.uk/product.php?prod=102930
Any suggestions?
__________________ Lounge Panasonic 50PX60-Sky HD 1TB-Yamaha AX763-Canton 151-Panasonic EX75-Xbox360 Garden Room Toshiba 37WLT68-Sky+-Sony S800-Oppo 971 Bedroom Samsung 32A457-Samsung F1080 Study Quad Core 6600/2tb/4gb-Mission Cyrus-B&W DM10-BenQ 24" monitor Dining Room Pure DAB-Cambridge Audio A5-Wharfedale Diamond 9 |
25-03-2007, 3:37 PM
#2 (permalink)
| | Member
Thanks: Gave 50, Got 18 | Re: Low white cabinet needed
hi
I was in the same postion last month and ended up making some units out of MDF and painting them. If you want sometning which matches the rest of your furniture you could have it custom made in a cheaper wood (pine) and painting it yourself. Custom made furniture can be expensive though. I can't think of anywhere else you could try on the net other than the companies you list in your post.
Good Luck!
25-03-2007, 7:45 PM
#3 (permalink)
| | Member
Thanks: Gave 7, Got 25 | Re: Low white cabinet needed
Thanks Joebo,
I am DIY-deficient. I can't even put up a Black and Decker Workmate without having a nervous breakdown. True.
Anybody out there with a suggestion.
26-03-2007, 1:09 AM
#4 (permalink)
| | Member
Thanks: Gave 11, Got 22 | Re: Low white cabinet needed http://www.ikea.com/webapp/wcs/store...roductId=11149
not exact, but relatively close... remove the castors maybe
__________________ Toshiba 37AV504DB | HTPC | Sony PS3 | NAD C320 | Wharfedale 9.1 |
26-03-2007, 12:03 PM
#5 (permalink)
| | Moderator
Thanks: Gave 91, Got 365 | Re: Low white cabinet needed
Moved to Stands etc
__________________ Visit my Home Cinema here |
03-04-2007, 7:46 PM
#7 (permalink)
| | Member
Thanks: Gave 13, Got 18 | Re: Low white cabinet needed
Read my mind Shep. I was going to recommend the same one
I'm getting it in black on friday, So I can let you know if it's built well if you like?
03-04-2007, 9:17 PM
#8 (permalink)
| | New Member
Thanks: Gave 0, Got 2 | Re: Low white cabinet needed
It looks good. Wasn't sure what to go for myself but thought but at this price if in 6 months time I don't like then I can soon go for something else.
Picked it up from the leeds store on Saturday, though the box was very heavy, it is surprisingly light yet sturdy when built. We nearly went for the black/brown one but change our minds at the last minute. After putting it together I noticed the finish has a kinda washed look to it, hard to explain but it is different shades of birch (if there is such a thing!). Would be interested to hear from anyone else who owns one as can't remember it being like that in the store.
At the end of the day you're getting a good looking bench for a steal of a price, also only takes about 15 mins to assemble  !
05-04-2007, 11:39 AM
#9 (permalink)
| | Member
Thanks: Gave 2, Got 14 | Re: Low white cabinet needed
THE OPTIMUm impression range - i1460 comes in white
size wise is h:450mm d:560mm w:1460mm
about £500, but seen for £350. one thing the box is huge as it is pre built
Pretty small half a chicken yeah sure what i dont much
07-04-2007, 10:35 AM
#10 (permalink)
| | Member
Thanks: Gave 22, Got 39 | Re: Low white cabinet needed
surprised no-one has mentioned this from ikea... http://www.ikea.com/webapp/wcs/store...umber=30086969
its low its white its glossy it has pull down doors, seems perfect ! just 'slightly bigger' than what you are after but its ticks all the other box's.
__________________ AV: Pioneer 436xde, Pioneer VSX-d915s amp, Pioneer DVD575a, Sony PS3 80GB, Sony BDPS550, Squeezebox Duet & Classic, Rel Q50 Sub, Audio Innovations System Alto, Marantz CD-6200, Genus DU-1 DAB, Chronos Hi-Fi Digital Reader
07-04-2007, 11:45 AM
#11 (permalink)
| | Member
Bit pricey though.
I got my Black LACK tv bench from Ikea yesterday.. Looks lovely, and is the perfect size.
Unfortunately, I can't put it together until I'm done decorating |
