Dimensions of Serano SB1050 stand
Old 18-03-2007, 3:11 PM   #1
6,564, Level: 19
Points: 6,564, Level: 19 Points: 6,564, Level: 19 Points: 6,564, Level: 19
Thanks: Gave 11, Got 7
Hi all.
Can someone give me the full dimensions of the Serano SB1050 glass stand.
I know it's 105cm width / 45cm depth / 53cm height (although it would be good if someone confirmed this) - but can someone tell me what the gap is between both shelves (height), as well as the space between the 2 front & 2 rear legs (width - ie how much actual 'useable' space there is on the shelves).
Many thanks!
Old 20-03-2007, 11:27 PM   #2
3,993, Level: 14
Points: 3,993, Level: 14 Points: 3,993, Level: 14 Points: 3,993, Level: 14
Thanks: Gave 12, Got 5
Re: Dimensions of Serano SB1050 stand
height between the shelves bottom-middle 20cm, middle-top 21cm
width useable space: back leg to front 37cm, middle support to front 41cm
think of it as a trapezius with the narrower side at the back.
hope it helps
Shwing (22-03-2007)
