13-03-2007, 6:11 PM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 0 | Argos glass hi fi stand..............opinions?
I've been looking at one of these for( http://www.argos.co.uk/static/Produc...i%2Bstands.htm )a while and was wondering about the followng, will it take the sony 1200es with the following dimensions:W430mm H175mm D430mm?
This weighs 15kg and the stand can take up to 40kg , i presumme thats a combined weight?
Plus i was wondering if the shelves are interchangable i.e can the larger bottom shelf be assembled / used as the top shelf.
Just wondered if anyone has any veiws and opinions etc?
13-03-2007, 6:57 PM
#2 (permalink)
| | Eminent Member
Thanks: Gave 1,138, Got 7,577 | Re: Argos glass hi fi stand..............opinions? Quote:
Originally Posted by james1967 I've been looking at one of these for( http://www.argos.co.uk/static/Produc...i%2Bstands.htm )a while and was wondering about the followng, will it take the sony 1200es with the following dimensions:W430mm H175mm D430mm?
Just wondered if anyone has any veiws and opinions etc? | Hi i have the exact cabinent and it's actually pretty good!I've got the Toshiba Xe1 on it,Denon amp.pioneer amp.the wii and all going well the Ps3 next week.Well over the weight but it's still nice and sturdy.
Yes you could mix up the shelfs if you wanted to.It's a nice looking cabinet,well worth the dosh,hope i've helped.
13-03-2007, 7:11 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 31, Got 126 | Re: Argos glass hi fi stand..............opinions?
The gaps are normally determined by the order you "attach" the tubes.
Capacity is 50kg.
13-03-2007, 7:21 PM
#4 (permalink)
| | Member
Thanks: Gave 0, Got 0 | Re: Argos glass hi fi stand..............opinions?
Cheers guy's
Its payday next Tuesday and i think thats made my mind up! |
19-03-2007, 4:08 PM
#5 (permalink)
| | Member
Could anyone post the dimensions of the larger shelves/spacings W , H & D?
Just want to be sure before i buy one.
12-12-2007, 11:39 PM
#6 (permalink)
| | Member
Thanks: Gave 24, Got 4 | Re: Argos glass hi fi stand..............opinions?
im thinking of buying this, but want to know if the bottom shelf will take my Denon AVR-2308, anyone?
13-12-2007, 6:45 AM
#7 (permalink)
| | Eminent Member
Originally Posted by adonis im thinking of buying this, but want to know if the bottom shelf will take my Denon AVR-2308, anyone? | Hi adonis
It can take a Denon 2807 receiver no problem on the bottom shelf.
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS PC13 Ultra  PS3 Slim, Oppo BDP-83, XE1, Logitech 1000 remote, wildlife pond in back garden and six fish tanks in the house.
Show me Potato Salad! |
13-12-2007, 10:41 AM
#8 (permalink)
| | Member
Thanks: Gave 2, Got 2 | Re: Argos glass hi fi stand..............opinions?
hey i bought this stand also just the other day. good and solid, all 5mm glass, wheras the top one is 8mm.
at the min all i got on it is my ntl box, and my pc sub, but looking to add on a htpc antec fusion case, and a onkyo 605 in the future job.
21-01-2008, 1:24 PM
#9 (permalink)
| | Member
Thanks: Gave 66, Got 45 | Re: Argos glass hi fi stand..............opinions?
Hi Guys,
Can anyone that has this stand let me know what the distance is between the bottom and second from bottom shelf please? Also can you leave a shelf off if you want when setting it all up?
I also need to know what's the actual width between the pillars?
I'm looking for something to put my Onkyo 605 in and not sure it will fit in this stand.
__________________ Xbox Live Gamertag: waser78 |
