Ikea friel
Old 11-03-2007, 4:08 PM   #1
13,972, Level: 28
Points: 13,972, Level: 28 Points: 13,972, Level: 28 Points: 13,972, Level: 28
Thanks: Gave 27, Got 45
Ikea friel
http://www.ikea.com/webapp/wcs/store...umber=30086969
anyone got one of these? if so have you got internal measurements etc? also are they pull down cupboads or drawers?
Old 14-03-2007, 3:05 PM   #2
1,865, Level: 10
Points: 1,865, Level: 10 Points: 1,865, Level: 10 Points: 1,865, Level: 10
Thanks: Gave 2, Got 0
Re: Ikea friel
Pull down according to that link
Old 04-04-2007, 5:35 AM   #3
3,678, Level: 14
Points: 3,678, Level: 14 Points: 3,678, Level: 14 Points: 3,678, Level: 14
Thanks: Gave 7, Got 25
Re: Ikea friel
Anybody else got comments on this one? I'm thinking of getting one today and i'd like to know any internal measurements, if the legs are removable and if the surface is gloss white or more plain.
Thanks.
Old 08-04-2007, 8:47 PM   #4
3,866, Level: 14
Points: 3,866, Level: 14 Points: 3,866, Level: 14 Points: 3,866, Level: 14
Thanks: Gave 3, Got 0
Re: Ikea friel
I have the Oppli TV stand from Ikea - I think it looks very smart, is low enough that the TV is at eye level when seated, once the shelves are filled with SKY HD box, PS3, etc. all the wires are effectively hided behind (unlike the glass stand I had before which expose the mess and tangle of cables). Friends are impressed and some have bought one after seeing mine.
The castors make it easy to move on wooden floorboards - and at 60 quid it's incredibly cheap (although far from cheap-looking) compared to the glass stands which, to me, look ugly in comparison and cost 3 x as much.
Hope this helps.
Old 10-04-2007, 10:09 AM   #5
13,972, Level: 28
Re: Ikea friel
Hope this helps.
Well no not really as you are talking about a totally different stand
Thanks for the info tho, the Oppli is a nice unit, just not the one being discussed in this thread you got the shop right tho eh
thats my lighthearted rant over lol
Old 23-07-2007, 10:30 PM   #6
3,730, Level: 14
Points: 3,730, Level: 14 Points: 3,730, Level: 14 Points: 3,730, Level: 14
Thanks: Gave 1, Got 1
Re: Ikea friel
Does anbody have the internal dimension for this unit then? Also a good photo showing the actual finish -- is it shiny white or just like a standard white MDF type finish?
I'm looking to get one but would be buying online rather than visiting the Sunday nightmare that is Ikea.
Old 21-12-2007, 12:30 PM   #7
3,678, Level: 14
Re: Ikea friel
Not got the internals but you can see from below what fits in it. It's not reflective shiney but it nicely matches my Ikea gloss white kitchen.
OMG - did I really say that
