Thought on Phoenix AV3 equipment cabinet
Old 18-01-2007, 10:49 PM   #1
4,736, Level: 16
Points: 4,736, Level: 16 Points: 4,736, Level: 16 Points: 4,736, Level: 16
Thanks: Gave 9, Got 4
Hello Guys
I have been looking around for a AV cabinet for a while now and I have come across this http://www.av-sales.co.uk/Phoenix-AV3-208-29.htm
I am just wondering if anybody out there has got one of these cabinets or at least seen them in the flesh.
On paper they seem to be just the thing I am looking for but £567 is a lot of money if it turns up and the quality is rubbish.
Any advice would be greatly appreciated.
Old 20-01-2007, 2:21 PM   #2
blicky_1's Avatar
6,367, Level: 19
Points: 6,367, Level: 19 Points: 6,367, Level: 19 Points: 6,367, Level: 19
Thanks: Gave 371, Got 119
Re: Thought on Phoenix AV3 equipment cabinet
One on this thread Walnut AV3 Cabinet
I'm going to look at one of these next week, looks quality kit though.
Old 20-01-2007, 4:09 PM   #3
4,736, Level: 16
Thanks for that Mate
Would You let Me know what You think of it please i see av-sales are doing a special offer on the av3 at the moment.
Old 20-01-2007, 11:06 PM   #4
blicky_1's Avatar
6,367, Level: 19
I have taken the plunge and ordered one from av-sales in oak tonight, will let you know how it goes!!
Old 21-01-2007, 12:09 PM   #5
4,736, Level: 16
cheers Mate
Old 22-01-2007, 10:10 AM   #6
4,682, Level: 16
Points: 4,682, Level: 16 Points: 4,682, Level: 16 Points: 4,682, Level: 16
Thanks: Gave 3, Got 2
Hello Mate,
Yep, I hae one of these AV3's in Oak and have just purchased the Plasma Bracket to go with it. (Wasn't available last year)
The Cabinet is great, nice materials that look and feel solid.
The delivery I took came with no assembly instructions whatsoever, which I am not sure is the norm, but anyone who has ever put anything together from Ikea will have no trouble.
On that note, thankfully the Plasma Bracket DOES come with instructions, and as this beauty holds several throusand pounds worth of screen, I am happy about that :-)
If I get a chance, I will take a piccie, but I suspect I won't have a chance to put the plasma bracket in for a week or two.
Regards,
Kirk
Old 22-01-2007, 2:19 PM   #7
4,736, Level: 16
Thanks for the info Kirk
Yeah I would like to see a piccie or two
Old 22-01-2007, 8:29 PM   #8
blicky_1's Avatar
6,367, Level: 19
Mine is beigh delivered Wednesday!!
Old 22-01-2007, 10:57 PM   #9
3,295, Level: 13
Points: 3,295, Level: 13 Points: 3,295, Level: 13 Points: 3,295, Level: 13
Thanks: Gave 6, Got 0
Really like the look of this cabinet. However its internal depth (460mm) is less than all of the Pioneer receivers from the 1016 upwards
How odd that a specialist cabinet should be too small for such a popular range of products.
Old 22-01-2007, 11:12 PM   #10
4,736, Level: 16
I will have to have a look in the morning regarding the dimesions of My Pioneer amp its the Pioneer Vsa-ax10ai-s it is a monster in terms of size but I am sure it will fit into this cabinet
Old 23-01-2007, 9:14 AM   #11
3,295, Level: 13
According to the Pioneer website that amp is more than 460mm deep...
I'm looking at the 2016 and this is too deep also
Old 23-01-2007, 8:00 PM   #12
blicky_1's Avatar
6,367, Level: 19
AV-Sales called today unit is comming tomorrow from Oxford fully assembled!!
Those Pioneer amps are very deep just measured my Yamaha 757se and its only about 400mm deep.....
Old 24-01-2007, 10:20 AM   #13
5,831, Level: 18
Points: 5,831, Level: 18 Points: 5,831, Level: 18 Points: 5,831, Level: 18
Thanks: Gave 1, Got 9
Blicky 1, make sure you examine the cabinet before the driver leaves. Mine was delivered this way, and was damaged in transit. Didn't spot it until the driver had gone.
Other than that, am very happy with mine. Replacement side panels have been supplied, but haven't got around to fitting them yet.
Si.
blicky_1 (24-01-2007)
Old 25-01-2007, 5:42 PM   #14
6,862, Level: 19
Points: 6,862, Level: 19 Points: 6,862, Level: 19 Points: 6,862, Level: 19
Thanks: Gave 24, Got 14
Mine arrived yesterday with no instructions? could someone post a picture of one with the centre part open so I can see if I have something missing at the rear?
Thanks....
Old 25-01-2007, 8:47 PM   #15
blicky_1's Avatar
6,367, Level: 19
Thanks....
Will try later for you but mine came fully assembled
Ther rear center is open though.....
Old 28-01-2007, 6:19 PM   #16
6,862, Level: 19
At the back of the centre part there are some holes drilled?
Attached is a picture of the bottom, any ideas?
Old 28-01-2007, 7:47 PM   #17
blicky_1's Avatar
6,367, Level: 19
This is for the optional screen bracket that feeds through from the top to the bottom, no need to worry
bolts (29-01-2007)
Old 30-01-2007, 9:39 AM   #18
4,736, Level: 16
Can You guys post some pictures of Your av cabinet please I am trying to convince the wife at the mo
Old 30-01-2007, 12:31 PM   #19
4,395, Level: 15
Points: 4,395, Level: 15 Points: 4,395, Level: 15 Points: 4,395, Level: 15
Thanks: Gave 0, Got 3
Has anyone got the Phoenix AV furniture with the Keene remote extender?
Does the Keene work well? I've seen other makes of remote extender for anything up to £250 so curious to know how well a £70 unit works.
Old 30-01-2007, 1:12 PM   #20
4,395, Level: 15
Also meant to ask how the doors open/operate as the pictures don't appear to show any door handles.
I'm looking for a cabinet with doors so that my 18 month old can't touch the equipment but didn't know if he would still be able to open the doors or if it would be possible to fit some kind of lock to them (or a Mothercare kitchen cupboard locking kit).
Old 30-01-2007, 4:33 PM   #21
5,831, Level: 18
Here's a picture of mine.
I am using it with the Keene IR kit, and it works fine.
The doors are on push catches. you push the door and it pops open. push again to close. They can take some adjusting to work just right, but it's no biggie.
Si.
Old 30-01-2007, 9:49 PM   #22
4,395, Level: 15
What finish is that?
Old 30-01-2007, 11:27 PM   #23
blicky_1's Avatar
6,367, Level: 19
Simkna's is the walnut finish, I have the oak.....more like the colour of his sub....
Old 31-01-2007, 9:25 AM   #24
45,524, Level: 52
Points: 45,524, Level: 52 Points: 45,524, Level: 52 Points: 45,524, Level: 52
Activity: 20.3%
Activity: 20.3% Activity: 20.3% Activity: 20.3%
Thanks: Gave 378, Got 854
where is the Keene receiver in that pic? I thought it was quite large - one of the advantages of the really expensive ones is that they have discreet receivers
Old 31-01-2007, 12:16 PM   #25
4,395, Level: 15
Blicky,
Do you have a picture of your one you could post?
Would prefer oak but there's no picture of the whole cabinet in oak on the AV-Sales website.
I would also be interested to see the Keene IR sensor in relation to the cabinet for an idea of size.
If it's too big can a different sensor be attached to the Keene unit?
Thanks guys.
Old 31-01-2007, 12:42 PM   #26
Assured Advertiser
Kent Home Cinema's Avatar
14,413, Level: 28
Points: 14,413, Level: 28 Points: 14,413, Level: 28 Points: 14,413, Level: 28
Thanks: Gave 62, Got 423
Morning all
Trying to see from the photo but the I think the Keene sensor/ receiver in Si's photo is where I have mine at home. You can see it reflecting slightly on the left hand underneath the screen. The receiver is approx 7cm at its deepest point and 7cm at its widest.
The cables lengths that come with the kit allow some flexibility where you put the sensor but as long as it is in line of sight with the remote there should not be a problem.
Regards
Alastair
www.kenthomecinema.co.uk
Proud to be be supporting the AVForums as an Assured Advertiser
Home of the FrontRow Home Cinema Seating Visit our blog - here
Old 31-01-2007, 12:50 PM   #27
4,395, Level: 15
Alastair,
I would like to get an AV2 but not sure whether it would be possible to stop an 18 month old from opening the doors. I don't think it would take him long to realise you have to push the door to release it!
Any ideas as to how the doors could be locked or kept shut?
Any suggestions welcome as I'm very keen to get one but the wife thinks we need something with locking doors (if it keeps sticky fingers off the Onkyo and Arcam then locking doors are for me too!).
thanks
Old 31-01-2007, 2:50 PM   #28
Assured Advertiser
14,413, Level: 28
Afternoon smarty
I have the same problem with my 15 month daughter and my AV3 She hasn't clocked the fact she can get into the cabinet yet as she is still enjoying climbing all over my sub and also trying to reprogramme my amp with the remote In a few weeks I am going to add a few child locks that that you can get for kitchen cuboards etc.
It might cost a little more but I can ask the manufacturers if they could incorprate some form of locking device without it spoiling the look of the cabinet.
Regards
Alastair
Old 31-01-2007, 5:00 PM   #29
4,395, Level: 15
Thanks Alastair.
I wonder whether a couple of these would work as locks:
http://www.mothercare.com/gp/product...72041&mcb=core
If you could find out from the manufacturer and it's not too expensive it might be a better option. I'll keep my eyes peeled for a reply ;-)
Regards
smarty
Old 31-01-2007, 5:31 PM   #30
Assured Advertiser
14,413, Level: 28
Hi smarty
Will contact the manufacturer and get back to you on whether they can provide locks.
Those child locks you have in your post should do the trick although I am not sure if there would be a problem with the current opening device. Will speak to the designers on this. I've used a similar Boots brand in the kitchen. The only thing I found tricky was for the magnetic type you have to drill into the doors (certainly with the boots ones you do). I was getting bored by the time I got to the 6th one and lost concentration and managed to drill through to the front face of the cuboard door Now planning a trip back to Ikea to get a replacement door.
Hopefully will get back to you tomorrow with news on lock options.
Regards
Alastair
