Help me with my storage please!
Old 16-01-2007, 12:40 PM   #1
gilford's Avatar
15,261, Level: 29
Points: 15,261, Level: 29 Points: 15,261, Level: 29 Points: 15,261, Level: 29
Thanks: Gave 522, Got 811
My situation is this, I have around 700 dvd's now, all of which are housed in the draws within the bed in my spare room. The bed is up against the wall so as you can imagine it is a bit of a nightmare moving everything when you want to watch a film. I did have them all on show in the lounge on shelving units but I have recently gone for the "minimal" look hence me hiding them all away.
I dont fancy those holders that you hook up to your PC as it would look stupid in the lounge plus I'd have to hook my laptop to it all the time. I like the look of some of these aluminium ones but I bought one for work a year or so ago and when it arrived it looked so cheap and the little pockets never hang right.
I do not have a problem at all with taking the dvd's out of the cases and storing the cases in the attic, I just need to have all the films to hand so to speak so I can watch them without any hassle, it seems pointless having them all at the moment due to it being a nightmare to browse through them and find one to watch
Any info appreciated. What are you guys using to house your collection?
Old 16-01-2007, 1:47 PM   #2
5,837, Level: 18
Points: 5,837, Level: 18 Points: 5,837, Level: 18 Points: 5,837, Level: 18
Thanks: Gave 32, Got 121
Re: Help me with my storage please!
I have reverted to the slappa cases www.slappa.com www.cd-wow.com sell them and the quality is superb. I havent gone for the DVD ones which take the insert sleeves aswell as you really are limited to the number you can fit in a case. So instead have gone with the 240 case which really is a 120 case unless you double them up with one disc behind the other which i have only done on double disc films.
Old 16-01-2007, 2:01 PM   #3
gilford's Avatar
15,261, Level: 29
Cheers for that, they do look like something I might buy
Sorry to be a pian but is there any chance you could take some pics of yours with the dvd's in it etc so I can get a good look at one in "real" life?
Old 16-01-2007, 2:07 PM   #4
5,837, Level: 18
If i remember by the time i get home I will!
Old 16-01-2007, 2:26 PM   #5
gilford's Avatar
15,261, Level: 29
Cheers bud, I'd really appreciate it
Old 17-01-2007, 9:28 AM   #6
5,837, Level: 18
Sorry completely forgot i told you i would i will put a reminder on my phone and do it later for you!!! sorry chief!
Old 17-01-2007, 3:30 PM   #7
gilford's Avatar
15,261, Level: 29
cheers bud
Old 17-01-2007, 7:03 PM   #8
12,192, Level: 26
Points: 12,192, Level: 26 Points: 12,192, Level: 26 Points: 12,192, Level: 26
Thanks: Gave 1,130, Got 518
How about a bunch of these? http://www.imation.co.uk/products/di...kka/index.html I know they`re pc connectable, but it would take a lot less time to pick one, even if they are in the bedroom, or new library/study
Not sure on budget, or below floor space, but you could have some sort of lift action jobby to bring them up from the floor.
Old 18-01-2007, 5:58 PM   #9
5,837, Level: 18
Sorry chief forgot last night but here they are....mine have taken a bit of a battering as my one year old loves to fiddle with them.
Help me with my storage please!-case-001.jpg   Help me with my storage please!-case-002.jpg   Help me with my storage please!-case-003.jpg
Old 22-01-2007, 10:19 PM   #10
Conspicuous Member
Dony's Avatar
7,469, Level: 20
Points: 7,469, Level: 20 Points: 7,469, Level: 20 Points: 7,469, Level: 20
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 942, Got 1,202
How about something completely different. Buy 2 and loop them together!!!!!
http://www0.dealtime.com/xPO-Sony-DV...www.google.com
Old 27-01-2007, 8:31 PM   #11
gilford's Avatar
15,261, Level: 29
Cheers bu5ter, just ordered 3 240 disc Camel ones to match my lounge
