Budget TV stand?
Old 15-01-2007, 11:02 AM   #1
gingerninja72's Avatar
4,758, Level: 16
Points: 4,758, Level: 16 Points: 4,758, Level: 16 Points: 4,758, Level: 16
Thanks: Gave 56, Got 48
Budget TV stand?
Hi guys, will shortly be ordering a 32" LCD and am having problems finding a cheap unit to house the TV plus consoles freeview etc. IKEA have exactly what I'm after, but they don't deliver - the IVAR fits the bill. It is cheap and the correct dimensions but I have no way of getting one. I need something
Less than £100 delivered
Wood - oak effect, pine, beech.
Enough shelves to house a DVD player, Humax freeview, 360, Wii
Dimensions: no more than 100cm wide and 40 cm high
Any ideas?
Old 15-01-2007, 11:16 AM   #2
3,903, Level: 14
Points: 3,903, Level: 14 Points: 3,903, Level: 14 Points: 3,903, Level: 14
Thanks: Gave 1, Got 7
Re: Budget TV stand?
Whereabouts are you? I'm waiting for a glass and metal unit to arrive, which will replace an Ikea unit that's very similar to the one you mention (therefore making it surplus to my requirements).
Old 15-01-2007, 11:24 AM   #3
4,758, Level: 16
I'm in Brighton mate. If me or the wife could drive, we'd go to Ikea in Croydon! My only option was internet delivery...
Old 27-01-2007, 8:06 PM   #4
montstar
Posts: n/a
Thumbs up Re: Budget TV stand?
Any ideas?
have you got this sorted yet gingerninja?
as i have one of these sitting in my basement unopened! bought it for the spare room and then the missus got pregnant! so the spare room is now a nursery
anyway im sure if i arranged delivery we could come to a price under £100
otherwise im just going to put it on ebay
