KEF iq1 wall bracket
Old 13-01-2007, 10:43 PM   #1
menz83's Avatar
Thanks: Gave 224, Got 203
Hey all, ive been looking for a set of wall brackets for my iq1's for a while now and have come up with nothing. I was asking in my local sevenoaks sound and vision and they said there were none out there because of the shape of the speakers. I have kept looking regardless and found these in the link below but I can only find them from a US supplier:
http://www.onecall.com/ProductDetails.aspx?id=32122
Looking at the vracket however, I cant see how these will fit my speakers. The only thing I can come up with is that you conect it to the bracket by the speaker connections but I doubt that could be the case. Does anyone know where I can get these in the UK or where I can find a suitable bracket?
Old 06-03-2007, 9:45 AM   #2
3,135, Level: 13
Points: 3,135, Level: 13 Points: 3,135, Level: 13 Points: 3,135, Level: 13
Thanks: Gave 28, Got 23
Re: KEF iq1 wall bracket
Hi ,
Did u manage to get any brackets?? I have asked my local dealer and they say Kef are showing them as out of stock.
They are going to call me back later to see if any other branches have them in stock.
menz83 (12-05-2008)
