Corner stand for a 42" that will fit a Denon 1907 ???
Old 10-01-2007, 8:49 PM   #1
jaarus
Posts: n/a
Can anyone help?
We are looking for a corner stand for a 42" LCD that has enough depth to hold a Denon 1907 receiver, which is 42cm deep (excluding all the little jacks and stuff out the back!)
They seem to either be 40cm deep or a little larger but with an internal cable tidy or whatever bring the actual depth back to 36cm or something similar.
Budget of under £200
Anyone got a 1907 and a corner stand??
Old 29-01-2007, 5:40 PM   #2
3,880, Level: 14
Points: 3,880, Level: 14 Points: 3,880, Level: 14 Points: 3,880, Level: 14
Re: Corner stand for a 42" that will fit a Denon 1907 ???
I'm also looking for a similar solution.
Anyone with some advice?
Old 30-01-2007, 8:42 AM   #3
jaarus
Posts: n/a
Update -quite a few PINE corner stands on available on the net, sadly new PC so lost my 'favourites' or would provide you with a big list of sites and models we were mulling over.
If you do go pine do check around as they are basically the same models sold everywhere with different names and a MASSIVE range in price, £119 one place and £450 another for the same model number cabinet stand was the prime example we came across!!
We arent looking for a corner unit anymore, instead we are going for a rectangular stand in the alcove itself so we are looking at the Sonus stands and the Soundstyle ST310 now. Both about a meter wide (total) with 900mm wide shelves that are 45/50cm deep with open backs.
Hope you find something you like
Old 30-01-2007, 8:46 AM   #4
3,171, Level: 13
Points: 3,171, Level: 13 Points: 3,171, Level: 13 Points: 3,171, Level: 13
Thanks: Gave 78, Got 31
http://www.avforums.com/forums/showthread.php?t=462967
