Word of WARNING ! ...............
I've had this stand [with floating arm] in place since August-06 and all seemed fine until earlier this afternoon when I noticed my 42" Philips LCD panel had 'dropped' down as I could see the panel mounting brackets appearing over the top of the screen.
On closer inspection I discovered that ALL four plastic/rubber mounting bushes had perished causing a loss of friction in the design fastening between the stand frame and LCD panel.
see attached PDF for pics]
I called the store where I purchased the stand and luckily they had some stands still in stock and agreed to replace the mounting bushes for me.
I think this is a design fault and the bushes perish easily due to heat from the rear of the screen or the compressive force in place when the panel securing bolts have been tightened. Glad I saw this when I did - who knows what could have happened if I had ignored it ? Suggest you check yours out now if you have the floating arm version.
Has anyone else has had this problem ?
