Can anyone recommend a tall narrow enclosed AV center(Plasma is wall moun
Old 02-01-2007, 2:43 PM   #1
11,037, Level: 25
Points: 11,037, Level: 25 Points: 11,037, Level: 25 Points: 11,037, Level: 25
Thanks: Gave 2, Got 7
I am trying to find a tall narrow AV center with doors (bc keep little kids out)? Where stores (online) should I check out? I have come recently from NY so not as familiar with UK stores.
Salamander in the US make such cabinets.
Old 08-01-2007, 9:33 AM   #2
my-planet's Avatar
2,757, Level: 12
Points: 2,757, Level: 12 Points: 2,757, Level: 12 Points: 2,757, Level: 12
Thanks: Gave 26, Got 7
Re: Can anyone recommend a tall narrow enclosed AV center(Plasma is wall moun
I'm looking for the exact same sort of thing. Best thing I've seen so far is from ikea: Effektiv. Instore (enfield) they had one made up with glass doors at the top, normal wooden door at the bottom. But my amp is a little bit too long, so need to think about carving up the back of it, and pushing the amp through.
Was around 100 quid.
Let me know if you find anything.
