Go Back   AVForums.com > Other Home Cinema Essentials > AV Stands, Cabinets, Seating and Furniture
Today's price checkPowered by
The Furniture Factory Worcester TV Entertainment Unit
Caxton royale wide tv entertainment unit
Metropole Ocean TV entertainment unit
Caxton Coniston wide TV entertainment unit
The Furniture Factory Worcester TV En...
Caxton Coniston wide TV entertainment...
McCord Lynx TV Entertainment Unit
Solo Flatscreen TV Entertainment Unit
Town House countryman long TV enterta...
Balmoral TV entertainment unit
Vader TV entertainment unit
Wall mountable TV entertainment unit
 More...Prices updated November 23rd at 2:30pm and include delivery.
Old 01-01-2007, 4:06 PM   #1 (permalink)
This Aria Plasma TV Stand any good for £52.58?
Does anyone know if this is any good for £52.58?
Click image for larger version Name: MON-STND-GJ-02-1.jpg Views: 4 Size: 63.0 KB ID: 44602
Plasma TV Stand GJ-02
http://www.aria.co.uk/ProductInfoComm.asp?ID=21488
I might buy it for my new 42" Panny I'm getting but I'm a little bit dubious due to the lack of any reviews for it...
phillai is offline   Reply With Quote
Old 01-01-2007, 4:35 PM   #2 (permalink)
Thanks: Gave 0, Got 14
Re: This Aria Plasma TV Stand any good for £52.58?
I bought a 37" LCD tv of them and this stand. My honest opinion is that this stand is excellent value for money its well built and looks and awful lot better in the flesh than it does in the picture. The only downside is that it takes a while to figure out how it goes to together as the instructions are rather rubbish. All in all an excellent buy.
yaris123 is offline   Reply With Quote
Old 01-01-2007, 4:52 PM   #3 (permalink)
Thanks for your reply... I take it, it's quite sturdy then, right?
Old 01-01-2007, 6:20 PM   #4 (permalink)
Thanks: Gave 0, Got 3
Hi yaris123,
Can you let me know what the dimensions are for the shelf? I need to know if they will hold two pieces of equipment (side by side), and judging by the picture it looks as though the shelf tapers towards the rear.
Thanks,
Steve
stevej is offline   Reply With Quote
Old 01-01-2007, 7:18 PM   #5 (permalink)
Yeah it is very sturdy. I dont know what the dimensions are but ive got everything stacked next too each with room left over. Ill try and post a pic when i get chance.
Old 01-01-2007, 7:38 PM   #6 (permalink)
Yes please! Yeah I wanna see how all my consoles will look - I hope there is more than enough space...
Old 01-01-2007, 11:07 PM   #7 (permalink)
That's good to hear; I've been having problems obtaining the spec' from Aria (I'm looking at the LCD stand, same spec' but one more shelf) , it hasn't helped having Christmas in the way!
It would be good to actually see a pic (with equipment on the stand).
Steve
Old 02-01-2007, 10:55 AM   #8 (permalink)
Thanks: Gave 3, Got 4
Check out the 2nd one down http://www.aria.co.uk/ProductsList.a...e=PLASMA+STAND
coolio is offline   Reply With Quote
Old 02-01-2007, 12:46 PM   #9 (permalink)
Yeah I noticed that one before... Do you think you can put more consoles and that on this one you showed me or the one I showed you before?
Old 02-01-2007, 2:35 PM   #10 (permalink)
For the 1st one I think you have basically one wider, deeper and higher shelve. I am not sure how usable the top shelf is if you have a bigger plasma.
Then you have the 3 floating shelves which aren't as high, etc. Depends what you have and how you can see them slotting in. I would ask them a question for exact measuremeants and then in your mind work out what you would have where.
Old 04-01-2007, 9:52 PM   #11 (permalink)
does any one have on of these stands
http://www.aria.co.uk/productinfocom...pecialStatus=1
can you tell me the sizes of the shelfs?
any info would be much appreciated
voodoo123uk is offline   Reply With Quote
aria, good, plasma, stand, £5258
